ve brakes
GEENZY
queensland
09 ve wagon sv6
hey guys i changed the brake pads yesty and everything went on fine but brakes are holding on a little and tricks plz
Fu Manchu
WA.
Remove the callipers again, grease the guide pins. Reinstall. I’ve always used High temp bearing grease.
If anyone knows of something better, please let me know.
greenacc
Searching for the billion
VE Berlina
Did you make sure you put the inner and outer pads in the right position? If you didn't know the inner and outer pads are different and just fitted them randomly you need to pull them out again and install them in the right positions. You might have 2 inners on one wheel and 2 outers on the other, or an inner and outer swapped over.
