Ve Brembo 4piston on VF
Martyr
I think your username should be Elusivedreams. That would imply you know what they are but that they are out of reach.
Illusivedreams makes it sound like you don't even know what your dreams are.
dgp
You need to take a little more care when compiling your post mate. What does it mean when you say "I don't want to drive out staff"? But you will if stock fit?? What are you going on about?
SnowDoggyDogg
2ltr? = Only milk & juice
I admit I didn't want to take the time to decipher the gibberish in your post.
IF you are simply asking can VE brembo fronts bolt on to a VF? The answer is yes.
dringy
VE Brembos have 12mm bolts, VF have 14mm bolts on the front. You can fit them but you have to drill out and re tap the
caliper.
Heheh.
That was my intention but at the age of 12 I couldn't differentiate between the two.i have used this this nickname for many years.
Sorry about the language. Autocorrect on phone and late typing.
Yes I simply want to use VE Brembo calipers on VF.
I'm reading that I require to drill out to 14mm.
Can some one confirm thread and pitch .Eg M14 1.25
426Cuda
SUBLIME!
Heheh.
New ones on Amazon are not that expensive. I'd check them out first.
SnowDoggyDogg
I've drilled out the front knuckles to accommodate a larger bolt but I wouldn't drill out the caliper.
I'd use the VE m12 bolt and where the you have the larger front knuckle hole of the VF just get a piece of tubing that has an OD of 14mm and an ID if 12mm to make a sleeve.
The bolt threads onto the caliper not the knuckle so theres no issues using a sleeve.
Are these part numbers you have listed in another thread for the front for VF? or VE
This should help anyone scouring the parts lists on Amazon.com or US Ebay:
Front 6 piston
Silver
GM#25912967
GM#25912477
AC Delco#172-2488
AC Delco#172-2487
Yellow
GM#20982719
GM#20982734
AC Delco#172-2521
AC Delco#172-2522
Front 4 piston
silver
GM#89047726
GM#89047727
AC Delco#172-2288
AC Delco#172-2287
Rear 4 piston
Silver
GM#89047743
GM#89047742
AC Delco#172-2308
AC Delco#172-2309
Yellow
GM#20982644
GM#20982647
AC Delco#172-2523
AC Delco#172-2524
SnowDoggyDogg
14mm bolt for the Chev/Caddy calipers listed above.
SnowDoggyDogg
Nah the shopmate service from Aus Post is pretty flawless.
RED LION
Yep thanks to SnowDoggyDogg I went through Aus post. Worked very well. Also 20% discount on shipping on your first order.
Getting the paint off them tomorrow, ready for painting on Sunday.
3rspecB
@ Red Lion, keep in mind that the front camaro calipers, the brake hose attaches at the top of the caliper and for the OE Holden front brembo calipers, the brake hose attaches at the bottom refer pic. When you fit make sure your brake hose isn't rubbing on anything..
RED LION
Thanks mate. Hopefully the mechanic does this on Tuesday. I'm sill paranoid about needing the longer bolts. But brakesdirct swears I don't need any.
KING46Calais V
caliper.
Retap the caliper?
Is there threads in the caliper.
I thought the only threads were the end of the bolt to the knuckle.
Are the holes in the caliper 14mm?
KING46Calais V
I'm in the process of buy some new brake lines for my VFII
I thought all VF were the same. But apparently not.
Got this response from a supplier
"Hi, VF2 has different inner mating surface in the fittings VS VF1."
Anyone heard of this or know what they are talking about.?
