VE Calais Lowered, 20" Rims
ozziieee
Shepparton
VE Series 2 Calais
I am looking at putting 20" rims on my VE Calais! if i were to also put SSL springs on it does anyone know how much room ill have between my wheels and guards? send photos if you have any!
jr_
Donating Member
VE II Sportwagon
whilst waiting for someone with a Calais and 20" wheels to reply, take a look through this thread:
measure your centre of your wheel hub to top of guard/eyebrow and compare with other Calais
https://forums.justcommodores.com.au/threads/king-springs-ves.152423
Also, vital info to an answer for you:
- is your Calais a V6 or V8?
- is your Calais a Sedan or Wagon?
As on VE's, a V6 need 1 level lower on front to be (approx.) same height at back, ie check out the King Springs catalogue: http://www.kingsprings.com.au/catalogue/Kings Superlow Caralogue 040203.pdf
Below Part No's for Calais Sedan:
V6 SuperLow Front: Part #KHFL-150SSSL+
V6 SuperLow Rear: Part #KHRL-152SSL+
V8 SuperLow Front: Part #KHFL-150SSL+
V8 SuperLow Rear: Part #KHRL-152SSL+
42
ya mum!
It will depend entirely on the offset of the rim. If you're talking about any Holden and HSV OEM 20 inch rims, there will be no issues with clearance even with SSL springs. If they're after market rims, what are their full dimensions/specs incl. offset?
jr_
Donating Member
VE II Sportwagon
good point! i read this as a height question not an offset question...
this thread may help as it has some links to offset calculators: https://forums.justcommodores.com.au/threads/rims-calais-ve-v-6ltr.93505
ducker85
Narnia
09 VE clubbie R8
Depending on your OFFSET and just as Importantly WIDTHS I'm gonna say heaps!!!!
Don't car how low your are with Holdens HSVi series of 20x8s with 48P offset, geniune HSV 20x8.5s with 36P fronts and geniune HSV 20x9.5s with 57P rears you'll have like 15mm inside and 20mm out.
And make sure you have a wheel alignment!!! -2.5 or -3 degrees of camber can affect your wheel fitment by up to 10-15mm.
