Ve Calais V Redline
myksomerville
51
Armidale
Ve SSV S2 Redline
The plate in the engine bay should say FE3 suspension as a quick check, but VIN decode is the way to go
Quentin
62
western australia
VE Calais 6.0 V
I'm a calais owner...Also different rear mufflers- Calais has one exit pipe splitting into two chrome tailpipes, others 2 exit pipes into two tailpipes. Calais mufflers bigger, quieter. Barely tell it's a v8. They give me the shizens, a V8 with barely any note.
Fu Manchu
Septic Tank Pump Operator
WA.
Slug powered VZ, Cross 8 VZ, VE Calais & ya mum.
Fu Manchu
WA.
I swapped our V6 single outlet mufflers for SS with dual outlets. The exhaust dimensions from the cats to the rear is the same V6-V8. Same dimensions of the muffler as well
All models had single inlet. One left and one right side of the car, other than base models.
You could use a dual outlet factory muffler from VE/VF SS to get it sounding better on a budget, but they are getting hard to find now.
mpower
easily fixed.
