VE Car Battery Replacement
Holdfast
VE Sedan Country Pack
Guys, I have a 60th Anniversary VE Sedan standard 3.6-litre V6.
She's nearly 5 years old now, so I was wondering if I should replace the car battery?
I haven't had any problems with the car electrically, but just thinking of replacing the battery bfefore something goes wrong.
Is five years time to replace or not?
Thanks
H
lease1
SSV Ute
Replace it when the car doesn't start.
WIKED
Gold Coast
VE GTS LS3
My HSV is now 4yrs old and I just replaced the battery with an Optima D34 yellow top.
The car started fine but would drop cruise control on the freeway when the window was put up sometimes. I didnt want to come out from work one day and it was flat so I elected to change it.
Holdfast
Cheers WIKED
I do a bit of hunting and fishing and didn't want to get stuck out bush.
Looks like I'll replace the bat then if you only got 4 years.
H
uniacidz
Harden the Frak Up
Sideneee
VE Berlina
3-4 Years is the norm for batteries.
Also look for warranties.
I use a AC Delco brand. 530CCA
arronm
FPV F6 VF Redline WGN
Cheers WIKED
H
5 years is a good run. If you are concerned just replace it. Then you will have peace of mind
greenacc
Searching for the billion
VE Berlina
I got 5 years out of mine then one morning i went to start it and nothing happened......
gossie
Gold Coast.
VE International 3.6L
Just replaced mine at nearly four years old. Better to be safe than sorry I felt before it gives up the ghost one morning.
Grumpyoldb
2013 VE SS-V Z Sedan Perfect Blue
I would replace it if you don't have road side assist and go to off the track places and don't want to be stranded. 5 years is a very good run from a battery IMO.
uniacidz
Harden the Frak Up
Sideneee
VE Berlina
Um yeh, if you can afford it, get roadside assist as well.
Saved my ass a few times.
