VE Comm SSV oil usage
rdruce
VE Commodore SSV
Is anyone having a problem with excessive oil use in their VE V8?
Spargo
holden tech
mid north
VT HSV Senator (SEN87A), VT V6, 90' Laser EFI.
how much oil is it using??
sump gasket's are starting to weep on these things,
have it checked next service
Reaper
Tells it like it is.
RG Z71 Colorado, 120 Prado , VDJ200, Vantage
Nope. Haven't added oil in over 150,000km of driving these cars.
Reaper
samdssv
SW Victoria
'08 VE SS-V Manual
mine will go down slightly from full between services although never needed to add any as yet, have also noticed very slight leak around sump gasket which will keep an eye on..
mov
VE SS V IGNITION
YEP!
I had Holden do a Oil Consumption test (basically fill it up and notify them if the warning comes on again. They check the amount consumed over the distance travelled and time frame.)
I had an oil warnings prior to my service interval starting at about 50K km's.
Holden ended up replacing the rings....they had the car for 10 days.
Don't know why but all ok now.
