DavesSV6Tonner
- Mar 25, 2019
- 640
- 1,526
- 93
- Location
- Australia
- VZ S V6 Cab & Chassis
Stick with GM or Mackay, avoid Kelpro, they are rubbish. I know from 1st hand experience.
It's a painful job because of the limited access so you really want a good set of tools for this. If removing the plastic guard lining makes the access easier then do it. The top nuts on mine were super tight so I ended up using a rattle gun from the top which wasn't easy either!
Your not wrong. Plenty of bad words were used in the undoing of those top nuts.Wow!! That would have been a mission
You can barely see the nut from the top
