Ve commodore speedo not working
Discussion in 'VE Holden Commodore (2006 - 2013)' started by hosking93, May 5, 2012.
  1. hosking93
    hosking93 New Member
    st clair sydney
    ve commodore sv6
    Hi guys, i have a 2008 ve commodore sv6 manual, and today i was driving home from the city, coming down the m4 the stabilty control flashed on the dash followed by the abs light followed by the brake light and contact dealer flashed and then the speedo dropped to zero. any ideas why this would do it? anything i could do to fix it?
    cheers ben
  2. BigBoss
    BigBoss Active Member
    VE Omega
    Possibly a stuffed cluster or BCM
  3. djlennane
    djlennane New Member
    Newcastle
    VE II SS/300zx TT
    I got a II VE SS, my dash started acting up (Random speeds etc) took it back to holden and was a problem within the cluster itself
  4. panthergreen
    panthergreen New Member
    VE SS karma blue
    how much did it cost to fix? mines showing engine and esp lights as well as no working speedo, friggin annoying...
  5. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 6.0 470rwhp
    Sounds like its lost the signal from the vehicle speed sensor.
  6. panthergreen
    VE SS karma blue
    big job? costly?
  7. RiCeY
    Australia
    Depends on the cause, first step would be to get the DTCs read to give an idea on what the issue is.
    krusing likes this.
  8. panthergreen
    VE SS karma blue
    no worries, thanks
  9. Jeremy Williams
    Jeremy Williams New Member
    Moe
    VE SS MANUAL S1
    Hey mate digging up an old thread, howd you go with this? Any success? I'm in the same boat
  10. krusing
    krusing Well-Known Member
    Bayside Melbourne 3193
    2nd that !
  11. krusing
    Get it scanned, and take it for a drive and check the live data, to make sure the speed sensor is actually working.
    VECalaisV8Wagon likes this.
  12. Jeremy Williams
    Moe
    VE SS MANUAL S1
    All that will come up in scan is losy connection to EBCM and the codes nor speed can be read, unfortunately, I've done rear harness, battery, checked fuses, ABS module has power there,
    Only other thing is I can't see a main earth on the block itself, only a chassis to head
  13. krusing
    I think there is a Earth terminal around the Alternator somewhere,
    As they were placing them as close as practical to the Alternator, in the event the engine was resistive.
    The Best thing is with live Data, is you can check the operation and compare reading on the dash,
    That can then give you a starting point of where to start looking,
    A lose BMC plug will cause all sorts of false readings and errors, and could be completely off track,
    But it then becomes a process of elimination, and probably very time consuming, but have to start somewhere.
  14. Fu Manchu
    Fu Manchu Well-Known Member
    WA
    Slug powered VZ, a VE Calais & your mum.
    I like how no one picked up on OP's name.
  15. krusing
    ? :confused:
  16. Fu Manchu
    WA
    Former editor of Street Commodores. Now full time Photographer.
