Ve commodore timing chain
Discussion in 'VE Holden Commodore (2006 - 2013)' started by livecommodores, Feb 28, 2012.
  1. livecommodores
    livecommodores New Member
    Dub
    ve berlina
    I have a 2006 ve berlina and the engine light comes on everytime i start the car, Iv been told by holden the timing chain is stretched. The light has been on for around a year and the car still runs fine no noises or anything. I think there is a little lack of power because of the light coming on but still runs good. My question is should i get the car fixed or just keep driving it?
  2. Rufys
    Rufys Banned
    VE Series II Calais Sportwagon
    It was/is a known issue and should be fixed under warranty. If your warranty has run out it's an expensive fix. Regarding the long term damage I have no idea but I can't imagine it would be good to drive it with such a fault! How can you drive it around with a known issue and the engine light on for a year and not be worried?
  3. livecommodores
    Dub
    ve berlina
    yeah it has no warranty and ive been qouted $3200 to fix it, it would probably cost just as much to put in another used engine?. Well it still drives ok
  4. gossie
    gossie Well-Known Member
    Gold Coast.
    VE International 3.6L
    As it's a known GMH issue, surely a NICE word with them should have it attended to at N/C or close to. Of course there other legal avenues a swell.
    By why in Gods name would you keep driving any vehicle when a warning light shines in your face?
  5. greenacc
    greenacc Searching for the billion
    VE Berlina
    Maybe because he doesn't want to bend over and get reamed 3k to fix holdens defective engine !! Certainly sounds like a stubborn move and its possibly going to end in tears. If the chain was loose though wouldn't it be noisy by now ? You could be a lucky man and just have a stuffed sensor ...
  6. VR6 NTOCSIK8
    VR6 NTOCSIK8 New Member
    Kwinana WA
    VE6 OMEGA
    Stuff it, assuming it's stuffed, and assuming you need to replace engine, just use it till won't go anymore, then get another engine
    Though this is a common fault, so it's dicky sensors, just because the code means stretched chain? Use it till she dies I would
  7. livecommodores
    Dub
    ve berlina
    yer it doesnt make no noise. Maybe it just the sensor and holden trying to rip me off?
  8. VR6 NTOCSIK8
    Kwinana WA
    VE6 OMEGA
    I wouldn except that it's chain rooted! If if drives fine makes no noise, doesn affect how it operates then don't worry, Holden puts these faults on here to make people get headf@&$Ed and spend money at dealer,
    I am not a mechanic but I would think most cars have a stretch just don't have fault code to indicate it, my opinion keep driving as per normal
  9. kizza50
    kizza50 Member
    VX acclaim S2
    Have you tried looking at the fault on a scan tool, and erasing it?? If it's just a sensor, could be Just a stored fault
  10. livecommodores
    Dub
    ve berlina
    Yeah ive had the code erased a few times it comes back up when i put my foot down hard or when it reaches bout 70-80kmh then stays on.
  11. livecommodores
    Dub
    ve berlina
    yeah ive had the code erased a few times just comes back up when i put my foot down or reached bout 70-80kmh..
  12. vn4250
    vn4250 vedelta
    Wollongong NSW
    VE Omega & VP Exec
    The sensor is easy to change. See if it's that first. Otherwise if not then you're up for a major timing chain replacement. Don't just quote Holden for the job. Other auto workshops can do it for a lot cheaper. Sooner you fix it the better. I let mine to the point it started damaging the guides as well. You won't like broken fragments flowing & blocking the oil passages in your engine, very bad.
  13. spanks
    spanks Member
    MELBOURNE
    VE SS-V UTE,VE SS SEDAN
    When the chain stretches it brings up a code for cam phasing. The sensors are working correctly and are picking up the difference in timing between the cams and the crank. The chains won't neccessarily make any noise when this happens. But yes it will feel a little low on power due to the timing issue.
  14. pjdm1980
    pjdm1980 Shut up Jr I'm thinkin!
    Geelong, Victoria
    E1 GTS BUILD NO# 007, GQ Patrol.
    Clear the code drive it over to your nearest Holden dealer (not the one that's cleared the codes) and trade it in :wave: on one with a warranty, they made the dodgy shiz can deal with it.
  15. vicarious
    vicarious New Member
    SA
    VE2 SV6 SPORTWAGON
    haha i like your thinking, but the service history would be on holdens database, best of getting the code cleared privately ;)
  16. pjdm1980
    Geelong, Victoria
    That's what I meant. Lol
  17. vicarious
    SA
    VE2 SV6 SPORTWAGON
    haha, thats not how its written:beer chug:
  18. livecommodores
    Dub
    ve berlina
    yeah think i might just clear it and trade it in lol
  19. leif72
    leif72 New Member
    South Australia
    VE Omega 06
    Just thought id add to this thread, have recently bought a ve omega 06 with 90,000 on it, and although it drove well, found the check engine light came on after a few weeks, at the same time noticing a slight rattle in the engine. Went through all the scan tool, oil sensor process to get to the bottom of it, only to find out that the timing chain is stretched and that this is a common problem in in late vz`s , early ve`s. have been advised that im better off getting a new engine as the stretched timing chain could have done other damage, the cost is $4000 for an engine with 50,000 on it, which isnt too bad considering i paid $10,000 for the vehicle, so im still around market value, if id paid $14,000 id be out for blood!, apparently they used a thinner timing chain but rectified this in 09. For a timing chain to stretch after 90,000 kms is rediculous, but buyer beware i suppose.
