VE Drivers Door Power Loom Plug (windows, power mirrors)
Rob940
34
Binnaway
VE SV6
halfway through replacing the drivers door and having trouble locating the wiring loom plug that powers the door functions (windows, mirrors etc). Has anyone had any experience with this or know where the plug is located inside the vehicle. What dash trims need to be removed to find the plug. Have already removed bottom trim near pedals. Still can’t see where the plug is.
-Cheers
Fu Manchu
WA.
It’s there.
Fu Manchu
WA.
Rob940
34
Binnaway
VE SV6
It’s there.
Yes I know what the plug itself looks like, I just can’t seem to find where it is plugged into. It has to be somewhere near the pedals or something but I cannot see it.
Fu Manchu
WA.
Pretty sure I have a photo of it at home. I’ll have a look later.
Fu Manchu
WA.
I had a look but none of my photos have it, but when you undo the loom seal, you should be able to pull it through enough to disconnect it.
vywgn
1967 Holden HR Premier Wagon / 2015 VFII SV6 Sedan
Pull the loom out from the door side of the a pillar and the plug will come out with it and then you can undo it
Fu Manchu
WA.
I found this image. It kind of shows where the loom heads.
