Ve fe2 springs
johnni
Ve Commodore
Hey all, my ve currently has king spring/monroe gt shortened shocks combo and I'm finding the ride is a bit too firm (maybe I'm getting too old now and not 18 anymore)
I have a spare set of fe2 springs laying around.
If I fit the fe2 springs to the monroe shortened will shocks, will that give me a smoother and less firmer ride?
Will the fe2 springs give me a similar height compared to the height I Have with my sl king springs?
Jeda
WN Caprice V
If I fit the fe2 springs to the monroe shortened will dhocks, willthat give me a smoother and less firmer ride?
I'd say you'd need standard length shocks to run an fe2 spring properly.
johnni
Ve Commodore
Im also wondering if I need standard length shocks or if I csn use my shortened shocks
J_D 2.0
Ipswich
2009 VE SSV M6 on LPG and 2022 Kawasaki Z650L
If you use the shortened shock then the ride will probably be worse than your current setup as your permanently compressing the spring with the shortened shock to below what its normal length would be.
That’s going to screw with ride quality and handling. It could even make the car unsafe to drive if you end up with basically zero suspension compliance from the spring being permanently compressed and unable to absorb bumps.
If your going to do the job do it right and get the correct shocks for FE2 springs, they aren’t that expensive.
L
losh1971
Guest
If doing them yourself I'd give them a them a try.
The difference in length is about 10-12mm. I went the other way and fitted FE2 struts to my shorter coils and no issues at all.
If you're paying to have them done then best to replace the struts as well.
L
losh1971
Guest
I'll add, SLs are not that short. You might find you have a bit to play with regardless.
Jeda
WN Caprice V
Not sure about the ute, but the caprice rode shithouse on kings SL's with standard shocks.
Changed to monroe gt sports short shocks and the thing rides and handles like a dream now.
L
losh1971
Guest
I have FE2 struts up front, and Walkinshaw lowered coils. Handles great on the ute.
Fu Manchu
Auto Correct is not my frog ballet.
Western Australia
Kia Sorrento, VZ Crewman, VZ Cross 8, & ya mum.
My VE Calais was on low Kings. Not happy with them.
L
losh1971
Guest
I'm not a fan of King Yellow's they are quite harsh compared to other brands and even some of their own factory stuff that's relabeled and sold under a different brand.
