Wickham_1995
- Jun 9, 2014
- 23
- 0
- 1
- Age
- 29
- Location
- Victoria
- E2 Senator Signature
Hello everyone,
I know there are several threads on this but wanting to see if they're any updates or findings on it.
I have bought a 2009 E2 senator signature September of 2017. A week after buying I had symptoms of a failing fuel pump; would start but idle rough and a die, cranking but no fire and only way to get it to run was a bit to the fuel tank. After a a week or so dealing with the dealership getting it fixed under warranty I had a new fuel pump module fitted from hsv and things sweet.
14 months after new fuel pump fitted I once again had fuel pump failure. Mechanic took the fuel pump out and tested but no power at all, pump was dead. He checked all fuses, relays and wiring and all was a okay, no signs of wear. Ask about the state of the pump and filter and said that there was no gunk or grime on them. Also I have gone to the same fuel station (BP) same pump, 98 and never let it below 1/4 tank.
Tried our luck gettingwarranty through hsv and didn't want a bar of it so they went to order a pump module and said that it was superseded and to use another part number that must be now the one that's taken over. Ended up getting another fuel pump module through a local dealer or parts store not exactly sure but is a little cheaper than buying from hsv.
My car is running now nearly $800 later but wanted to know if anyone else has had issues with fuel pumps in their ves? And any information that may help. I hope I don't just have a dud
