VE GTS springs fit SV6?
Z-Tuned
34
SV6 Series II Z-Edition
Tried searching but only found that the VE GTS's run MRC suspension.
My question is, I've found aftermarket lowered springs to suit a GTS but was wondering if it would also fit a Series 2 VE SV6? I'm not bothered about the shocks/struts as I already have KYB's struts. Any help would be appreciated.
07GTS
Australia
VEGTS BLOWN E85
not sure if they fit the v6 but the gts with the v8 weights more so in the v6 the front might sit higher, also they are to suit mrc, but having the gts myself they sit way too high factory so id go different springs
ducker85
Narnia
09 VE clubbie R8
providing the GTS has specially designed springs to clear the MRC shocks Id say they wont fit so dont bother with them and just suggest buying the correct springs for your vehicle (the SV6)
Z-Tuned
34
The springs I was looking at getting (Tein S.Spec's) sat about a finger's width from the top of the tyre to the guard which wasn't too bad on the GTS but would have been abit higher on an SV6 given the weight difference which I preferred. Have contacted H&R and will go that route instead. Thanks guys
