actionmanmelb
Hi all, I am new here. I am having a problem with a 2009 VE manual HVAC system. It was stuck on recirc no matter what you did with the switch, and the windows would fog up all the time. As well the vent temp was always higher than ambient with the A/C off.
I decided to tackle the problem yesterday and trawled the net and this forum. Found some good info but not exactly what I need.
First thing I then tried was the "hold the demist button to do a flap motor recal", this resulted in full heat all the time. Worse than before!
I then removed the covers from the left and right sides of the dash. I then did another flap recal to observe the motion of the servo's. The floor face and the screen/demist were working, but the temp control and the recirc servo's weren't moving
Then I borrowed a friends scan tool and got two codes - B0228 and B0418. I cleared the codes, but they returned immediately.
I bought a new servo motor (P/N 92192343 - $15). All four servos are the same part and can be interchanged. I the swapped the heat control servo with the new one and when tested found that it would move but then stop in a default position of full heat.
I then swapped out the fresh/recirc servo and re-tested with the same results. By this time I figured the control unit was suspect as the fault codes would not erase even with the new servo.
I then bought a new control unit and after installation and doing a re-learn I could hear a faint whirring coming from the fresh/recirc door servo.... it was continuously running.
I then removed the blower to look at the recirc/fresh door, which by the way took some finding, as I could not see the wood for the trees! The door is right in front of the blower hole but looks like part of the blower housing.
When I moved the door by hand I realised that there was no connection to the servo motor.
So after all that........how do you replace the recirc/fresh door flap?? Please don't say it's a dash out job.:boxing:
