I've got another curly one with the dreaded HVAC actuators...
How critical is doing the "relearn" with the doors open?
My issue seemed to be a common one where everything works as it should except the Driver's side blowing only Cold air.
Performed the "Demister" test and found the Drivers lower actuator not working (#25 in the diagram on Post #67). Awesome, should be an easy fix... ordered a new one from Holden.
Having pulled the old actuator out the previous weekend and finding the flap drops with gravity to the Cold setting, I had managed to refit the old actuator with the flap partially up so that I had luke-warm air on the Driver's side for the past week. Saturday comes around and I start pulling it all apart again. I was then wondering whether the new actuator would automatically start at the cold setting for installation. So before I refit the new actuator, I figured I'd plug it in and do another "Demister" test and see where the actuator sits at rest. The actuator fired up, rotated fully in both directions, then stopped in the middle. OK, no big deal, I'll just start the car, and turn the A/C down to COLD and force the system to move the actuator to the same position as the flap. Only problem now, was that the whole system defaulted to the windscreen, and would not react to either "Demister" test or changing the HVAC controls. Hit the Demister button again, and only the new actuator goes through its motions. So, I unplug the new actuator, and it all returns to normal, doing what it was doing before, with all other actuators working as they should.
But... I may have had the Driver's door open, so does this effect the "test" or "relearn" procedure?
