VE HVAC actuator replacement.
Bec
VE Calais-V 6L Wagon
Thank you so much for this.
I have exactly the same problem, air coming from dash and windscreen but not feet, with the knocking noise when ignition is turned on. I tried the 'relearn' procedure this morning hoping that would fix it, but now I don't even get air coming out the dash, just the windscreen...
I'd already bought the actuator but even with the service manual I was wondering exactly how (and which one) needs replacing. This makes it so much clearer, I'll hopefully fix it today :)
Bec
Fixed mine today, that top screw is an absolute pain! I also had to use a fair bit of force to remove the panels. I pulled apart the old actuator to see what was broken, the white cog is supposed to have 2 sets of plastic gears, the lower set of gears needed to turn the yellow cog had been completely stripped.
Part# if anyone's curious is 92192343, I paid $21 from a Holden dealer.
blackve76
47
there
VE SS ute 360rwkw N/A, 2016 VF2 SS M6
View attachment 179295View attachment 179293View attachment 179292View attachment 179294
That top screw is a Bi#tch good to hear fixed, such small $$$ for a big pain
Lowgz
new Zealand
ve omega
Anyone had a problem with not being able to change the temperature?
DoMn8oR
44
Australia
2010 SSv
This helped me out a heap I think ( I hope). Is there a more detailed "How to" on this site? About this Topic?
My Ve SSv just started blowing cold air to the passenger side and hot on the driver's.
I did the reset by holding down the rear demist button.(when I do this it sound's like a stripped gear or broken) Now NO Vent's will open up !
But when I first did it it did stop the cold air from the passenger side!
Any help would be great!!!
Thanks.
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
haven't seen a how too, but one person did put up some pics earlier, google it here
DoMn8oR
44
Australia
2010 SSv
Yeah that top screw! It's just a BIG F***en pain!
Replaced mine today.
I pulled apart my old actuator too, look's exactly the same!
