VE LFX SIDI Gauge Install / Wiring + Senders
SimoHDK
2013 VE Commodore SV6 Z-Series - Manual
Hey All,
I'm looking to fit some gauges to my LFX SIDI. I'm after Oil Temp + Oil Pressure and/or Coolant Temp.
Does anybody know a simple way of doing this (other then purchasing the very expensive OBDII gauges)?
Apparently I can't just use a T connection on the stock oil sender - "The 2012 SIDI is a bit different, there is not sender adaptor available so the job requires you to drill and tap a hole near the oil filter cartridge, this is not a job for a low experience fitter, if you stuff it up it will cost $400 to get a new part for your motor from GM."
Anybody got ideas? I'm picking up a gauge pod with the 3 HSV gauges, but apparently the HSV gauges won't work with my car (I would love to be able to use them though!, anybody know how?)
Cheers.
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
see if you can get Zerone on this forum, hes into alot of this stuff, cant see why you cant use an adaptor (230.035BG T-piece Adaptor 1/8"27NPTF to M14x1.5) this fits alloytec engine) not sure about sidi thought fits near oil filter passenger side
