The1
A Memcal a Day Keeps..
- Jan 12, 2005
- 2,367
- 46
- 48
- Location
- QLD
- Website
- www.eyeit.org
- VS V6 Berlina Auto
here's a set of readings i picked from the logs before and after the MAF swap best as i could matchup. Went from Stock V6 MAF to the Silver Badged Delphi MAF 25168491, MAF tables the same just extended. Obviously fueling and spark needed retouching but other than that. There might be slight differences in readings between MAF's at the same flow but even then there is enough gain to say there is still a flow gain.
10231hz MAF
875cylair
5900rpm
53c intake temp
9444hz MAF
710cylair
5900rpm
54c intake temp
7934hz
653cylair
3500rpm
50c intake temp
7710hz
613cylair
3500rpm
45c intake temp
10231hz MAF
875cylair
5900rpm
53c intake temp
9444hz MAF
710cylair
5900rpm
54c intake temp
7934hz
653cylair
3500rpm
50c intake temp
7710hz
613cylair
3500rpm
45c intake temp
