Classic327
- Nov 14, 2020
- 6
- 1
- 3
- Location
- New Zealand
- VE Omega Commodore 3ltr - 82 Chevy Pickup
I just joined and hoping for a bit of advice. I just bought a set of 2014 SV6 mags with no wheel nuts. I am putting them on a VE Omega replacing the std wheels. Do I need mag wheel nuts or can I use the std wheel nuts and caps to fit the SV6 mags? The hole in the mag for the studs is 18.5mm so the threads on the studs won't make contact with the mag. I'm not sure if the tapered seat "mag surface to std wheel nut surface" is all that's needed to secure them properly (ie no wheel stud contact to mag). Or, is there a shaft on the mag nut that is meant to go inside the stud hole on the mag providing contact between the stud hole and the wheel stud? I haven't seen a mag nut and the mag shops are closed for the weekend. If anybody knows for sure I would appreciate your advice.
