Mikepsmith911
This issue has really started to do my head in so any suggestions/help would be much appreciated.
My VE had a faulty radiator and the power steering pump had a leak. So a mate of mine who is a qualified mechanic serviced, replaced the radiator, thermostat and power steering pump replaced.
Immediately after the above work was carried out the vehicle was misfiring (3 cylinders) my mate was unable to resolve rhe issue so I had another mechanic look at the vehicle and check over misfire remove manifold, replace plugs and coils, refit with new gasket.
I thought this fixed the problem but the vehicle still 1) Idles roughly 2) misfires occasionally - though not to the extent it was 3) shudders.
Any suggestions or comments as to how / what is causing this????
