VE Omega Auto to tiptronic gear selector
anthonyenzo2012
Darwin
2008 VE 60th Anniversary Lumina
This may be the dumbest question to ever touch this page but I just cant find anything anywhere.
I have a 2008 Lumina which is the same as an Omega just with a few extra's. It has a 4 speed Auto box with a straight line gear selector which you can also select 1,2,3 gears under the standard P,R,N,D.
Can you swap that with a gear selector that has P,R,N,D and also the tiptronic option where you push the stick to the left and use the + or - to manually select gears??
I'm definitely not looking at changing the actual gear box just thought the extra feature could be something fun to use.
As its an electronic box id assume this would work but could also be the dumbest question too.
TazzI
Envyous Customs
Western Australia
www.envyouscustoms.com
Holden VE SS Ute
Iv not attempted this.. but.. as long as your BCM, ECU and TCM support it.. I don't see why it wouldnt be a plug and play upgrade.
Best to probably check wiring diagrams as well incase there is anything missing between trip and non triptronic shifters.
Lachie Fulvio
VE
hey i was thinking of doing this, could you please let me know if it worked before i go tearing stuff apart? cheers
