VE Omega cruise control in sports mode
LeighC
Northern Victoria
Omega V Commodore V6 Dual Fuel
Hello all,
After info on getting factory settings changed.
I have a VE Omega Jan. 2007 V6 LW2 factory dual fuel (LPG) 4 speed auto & ever since new when I go into sports mode my cruise control switches off, does any one know how I can prevent this from happening please, it is a real pain in the bum.
Thanks - Leigh
LeighC
Northern Victoria
I've been told the later models the cruise will work in sports mode, can any one confirm this please?
I have a long trip coming up towing a trailer which the owners manual says to use sports mode.
Cheers - Leigh
lout
60
Langwarrin Victoria
afaik cant be done without a custom tune
snortings
Queensland
MY15 SV6
Leigh,
From what I know from previous VE's when driving in sports mode and then setting the cruise control, it will take the car out of sports mode and back to normal. So I'm not too sure if the VE can be driven in sports mode with cruise control. This is on a 2007 model.
But I do know in my old 2011 Series 2 VE, that I could have the shifter in sports auto and still have cruise control function.
So I believe if you have the older style, PRND321, it will not work. But if you have PRND and then +/-, it should work.
Hope this helps.
LeighC
Northern Victoria
Thanks, yes mine is the old 4 speed auto & if I select sports mode my cruise switches off, I was wondering if a good man with TEC 2 could alter it. Cheers - Leigh
ChRiDDa
N/A
VE SS-Z Sportwagon
Just to clarify - when you refer to sports mode, You mean having the stick shifted to the left but not full manual mode?
If so, I can confirm that cruise does work - I operate my ‘12 ss-z wagon in sports mode all the time - never had an issue with cruise
LeighC
Northern Victoria
My sport shift mode switch is on the front of the floor gear console & SPT comes up on the centre dash when on & goes out when cruise is on.
I think I have it sorted out when I reread the owners manual, when cruise control is selected it is "neither sports or normal mode", maybe somewhere in between perhaps, I have never bothered to rev it & check out the change in shift speeds.
I will just keep on towing in cruise control which says it is allowed also.
Thank all for your help - Leigh
