VE Omega overheating
jasonjea
Sefton
www.aus-chat.com
VF Commodore SV6 UTE
hello guys
just got "new" Commodore Omega 2007 V6 and now i have problem with overheating!
temperature inside car on control is under working temperature but under hood he trows wather out. he dose not turn on vent's..
soo what can be problem ? i was at mechanic today and he say i need to se electrician.. so now when im driveing i need to turn on AC and he dose not overheat!
i really need to fix this ASAP by my self becouse i work monday - friday 6 to 4pm so dont have time to goo to mechanic!
thanks guys if u need more info just say i will try to explain with my bad english! sorry about that
ps: i was searching about that problem but i didnt find anything!
aaronevolution
Donating Member
Hastings, Victoria
TURISMO VZ SS 6.0
Turning your Air Con on should make your car overheat more. Turning your heater on full would be better.
Brenno
Woomba
VE 6.0L MY09.5 A6
Has coolant just been overfilled?
Or not enough actual coolant in the reservoir causing it to boil?
jasonjea
Sefton
www.aus-chat.com
yeah but when AC is on vents are spinning!
no i put coolant between add and max. when he get overheated he is throwing water from engine and car dont recognize any error and as u see on pic hot it stay all the time.
i was testing it in all ways and waiting to turn vents on but he didnt he just trow water out
dose this commodore have water sensor ?
example if i put water not coolant ?
jasonjea
Sefton
www.aus-chat.com
water is coming out from everywhere..from coolant resevoar where u put water and under it and from tube from engine to coolant.. i took out that tube from engine to reservoar and than it come out only from tube..so my point is he throw water only from engine..and it comes out from coolant reservoar becouse when he mix hot water from engine and that tube is going in coolant reervoar... OMG i hope you understund me what i mean :D
Benboy
Hill River, SA
2007 SVZ Wagon
Why have you included a phot of a vehicle dashboard? If it is to indicate the position of the Temperature Gauge, then it is probably in about the desired range for normal operating conditions. If problem persists, suggest you take vehicle to an Auto Cooling Specialist who will have necessary equipment to make informed assessment.
jasonjea
Sefton
www.aus-chat.com
Shorty33
Fly Creek, N.T.
VE Omega sedan 3.0 2010
as I was reading this thread, I was wondering if you might have a radiator cap problem.
I had to replace the cap on my VZ twice. So far, my VE hasn't had that problem.
Your temperature guage (pic) is sitting exactly where mine sits.
If I were replacing my radiator cap, I would stick to the manufactuer's recommendation.
Also, when you lose coolant, sometimes you only have access to water, so you use water to get home.
But every mechanic I have spoken to says that it is important to replace lost coolant with the correct coolant. If necessary, you might have to drain your cooling system and refill it.
jasonjea
Sefton
www.aus-chat.com
Yes i will do service this sunday and replace all that :D
