V6 Ex Police Ute 2010
- Nov 10, 2018
- 3
- 0
- 1
- Location
- Mudgeeraba
- VE LY7 2010 Ute
Hello I was looking to add - wire amp to standard head unit / using hi/low converter box etc....pretty easy standard stuff...but If you need to add tweeters to front that are not supplied with vehicle as standard...
Q.1/ Do you use / tap into the wires from existing head units front speaker wires at the back of the head unit ** but before they go into the low/hi/ wire / rc lead converter box which runs leads off to the amp....If so
Q2./ Would the standard head units front speaker output wires not produce too much power to damage the tweeters...?
Q3./ Would tapping into the front speaker wires off the back of the head unit first.. before they then continue off to the hi/low adaptor box.. not have a power input reduction enough to cause issues to the converter box it needs to convert hi/low to RC leads to the amp....Thanks for your time and help...Merry Xmas
