VE Omega wiring question
Discussion in 'VE Holden Commodore (2006 - 2013)' started by VE22NV, Aug 29, 2017.
  1. VE22NV
    VE22NV New Member
    SA
    VE2 OMEGA
    Hi Guys, first post, my names Steve.
    My son has a VE2 ex cop car which we need some help with and were hoping you guys are the right people to ask.
    The car came with a dual battery setup in the boot which I'm assuming the passenger side battery runs the car and the drivers side is for the police accessories.
    He lost his licence a few months ago and as it just sat for that period the battery went flat.
    I removed both batteries thinking they would both need charging, however, despite the battery on the passenger side being dead flat, the battery on the drivers side was still fully charged.
    With this in mind we discussed removing the secondary battery altogether as it obviously isn't necessary to run the car and takes up space and is considerably heavy to be lugging around for no purpose.
    So I removed the extra battery mount and removed all the wiring where it had been added to the existing battery, however, I was left with one wire that I'm not sure what to do with.
    From what I can tell it comes from the wiring loom on the passenger side, underneath the rear parcel shelf, is brown with a blue stripe in colour and had been extended to reach across to a redarc gizmo attached to the secondary batteries setup.
    The question is, what is this wire for and do I need to reattach it to the cars primary battery somehow or can it be insulated and taped up out of the way.
    Thanks
  2. MYVESSV8
    MYVESSV8 Well-Known Member
    Brisbane/GoldCoast
    VE 6LT M6
    what terminals did it go to on the redarc
  3. VE22NV
    VE22NV New Member
    SA
    VE2 OMEGA
    Thanks for the reply
    It goes into the circuitboard under the clearish cover attached to the side of an isolater like this one
    https://www.sparesbox.com.au/redarc-battery-isolator-24v-100a-max-sbi24-sbi24?utm_source=bing&utm_medium=cpc&utm_campaign=SPX - Shopping - Sub Category&utm_term=4579328490979548&utm_content=ALL Products
    I hope this makes sense
    The blue wire on the far side, what should I do with the wire which connects to it that feeds back into the cars wiring loom if not running the second battery, id like to make sure its not going to cause any grief before I reinstall the primary battery.
  4. MYVESSV8
    Brisbane/GoldCoast
    VE 6LT M6
    looking at the redarc drawings I would say a positive feed to activate unit/ when ignition on to charge battery, test with a meter or test light with accessories/ignition on and off if power there when ign on etc put it into a connector and seal up,
  5. VE22NV
    VE22NV New Member
    SA
    VE2 OMEGA
    An override feature apparently, so the secondary battery can be momentarily activated to power the car.
    I just taped it up and secured it up under the lining and reinstalled the primary battery. The alarm sounded so I locked and unlocked it with the remote and it was all good.
    Then when I started it there was no power to the dash and display and I thought i'd fried it but turns out the Police stealth mode thing had activated, so I tapped the switch and presto it was all there again..lol
    Bonus is we now have a complete dual battery system with 70ah battery for camping etc.
    Thanks again.
    MYVESSV8 likes this.
  6. Capsule
    Capsule Member
    Brisbane, QLD
    MY09 VE Omega
    Yeah I have an ex-cop as well but the dual battery setup had already been removed.
    I still have the redarc relay tho :) I should uninstall it properly, they just cut the wires and let the relay in there.
    Or rewire it properly and install a second battery, but my camping activities are close to zero :-D
