VE Part Numbers
N.E. Vic
2011 VE SV6 II Commodore - Chlorophyll
Hi All,
Searching for VE Part numbers tonight and came across this list
Hope it helps some members.
Edit: Couldn't Post up the Website URL as it appears to be blocked so here is a copy of the list.
Thanks to the poster on the original forum.
Ignition Dash
Glove box door
92173904 - $143rrp
Panel under steering wheel, without head lamp switch
92197332 - $96.25rrp
Dash strips “Ignition”
LHS
92173005 - $45.92rrp
RHS
92173002 - $45.92rrp
Dash Strips Silver (SV6)
LHS
92204532 - $38.50rrp
RHS
92204530 - $38.50rrp
Red-Hot Dash
Pad IP
92172858 - $324.50
Glove Box
92173903 - $143.00
RHS Fuse cover
92197331 - $96.25
Dash strips “Red Hot”
LHS
92173004 - $46.47
RHS
92173001 - $46.47
Calais Misc
Dash strip Calais type dash pad (Titan Etch) RH
92170857 - $126.50rrp
Dash strip Calais type dash pad (Titan Etch) LH
92170858 - $124.30rrp
Cover kit steering wheel (Micro Silver) (Steering wheel insert)
92194421 - $20.57rrp
Handle front door (Satin Chrome / Onyx) RHF
92186978 - $82.50rrp
Handle front door (Satin Chrome / Onyx) LHF
92186979 - $82.50rrp
Handle front door (Satin Chrome / Onyx)RHR
92186982 - $82.50rrp
Handle front door (Satin Chrome / Onyx) RHR
92186983 - $82.50rrp
Cupholder incl chrome surround (Onyx)
92171506 - $32.45rrp
Armrest sliding (Onyx)
92193806 - $291.50rrp
VE dash Strips also available
Micro Silver
Radio Silver
Onyx
Rado Gloss
Olivet
HSV binnacle
HOUSING - Binnacle Gauges (Onyx)
B06-060601 $335.50rrp
engine oil temp
12J-060602 - $206rrp
oil pressure
12J-060603 - $206rrp
voltmeter
12J-060601 - $206rrp
guage harnesses
Harness CSTR WRG RRP
12H060601
Harness M/Func Ga Wrg
12H060602
MRC Blank
SV-12F-060607 - $36.98rrp
Stereo Centre Stack trim
GM-92170900 - $13.09rrp
Ashtray Compartment
GM-92200591 - $60.50rrp
Ashtray Compartment Door
GM-92170909 - $16.39rrp
Gear Leaver Surround Trim
GM-92188262 - $58.30rrp
Rear Cup Holder Trim (I think ?) Not sure you better check
GM-92171508 - $11.99rrp
Calais V Exterior Chrome
Chrome Moulding Numbers
Moulding Top of Door Opening RH
92196052 - $126.50rrp
Moulding Top of Door Opening LH
92196053 - $126.50rrp
Moulding Chrome Front Guard RH
92180504 - $35.75rrp
Moulding Chrome Front Guard LH
92180503 - $35.75rrp
Moulding Front Door Lower RH
92180506 - $66.00rrp
Moulding Front Door Lower LH
92180505 - $66.00rrp
Moulding Rear Door Lower RH
92180508 - $47.85rrp
Moulding Rear Door Lower LH
92180507 - $53.35rrp
Chrome Bonnet Moulding Numbers
Moulding Hood Front
92190727 - $101.20rrp
Bolt Moulding Hood
92138773 - $0.70rrp (10 Required)
Retainer Hood Moulding
92059470 - $1.15rrp
92138009 - $0.70rrp (10 required)
Chrome Boot Lid Moulding Numbers.
Moulding Boot Lid
92195540 - $93.50rrp
Clip Rear Moulding
25724529 - $5.44rrp (3 required)
Radiator Cover (Baffle Rad Air upper)
V6
92179987 - $24.75rrp
V8
92183726 - $24.75rrp
Clip number is 92138218 for both (5) Approx $2rrp
SSV Rear Parcel Shelf (includes Speaker Covers)
92159946 - $236.50rrp
SS/SS V fog light surrounds
92181609 LH
92181608 RH
SV6 front bar cover (bare)
92161017 - $385.00rrp
SV6 Front headlights and rear tail lights
RH Head light
92155434 - $209rrp
LH Head light
92155435 - $209rrp
RH Tail light
92155446 - $165rrp
LH tail light
92155447 - $165rrp
SSV headlights to suit an SS VE Ute
Notice Change for MY08
MY07 SSV
Right Hand Headlight
92155444 - $374.00rrp
Left Hand Headlight
92155445 - $374.00rrp
MY08 SSV
92196422 - $379.50rrp
Left Hand Headlight
92196421 - $379.50rrp
HSV Wheel caps (will not fit 20" Supersports)
10B-030301 RRP$ 49.50
VE postive post/terminal
Batt Cable
92185943 - $187.00rrp
Batt Cable extn
92185945 - $11.33rrp
Bracket wrg harn
92186660 - $3.25rrp
Stud post jump start
92190434 - $8.74rrp
Block post jump start
92185950 - $15.29rrp
Cover post jump start
92190433 - $7.64rrp
Harness jump post to engine (V8)
92188799 - $102.30rrp
Harness starter
92188798 - $157.30rrp
Rear spoiler for G8 and Calais (Lip type)
92217652 - $225.50rrp
SS/V rear spoiler
92155458
SS M6 GM oil filter
89017524
Starter Motors
V8 upto MY08.5
92184951- $214.50rrp
V8 from MY08.5
92202964 - $247.50rrp
DECKLID Carpet (inside of boot)
Carpet
92171583
Clips (6 off)
92138253
HSV front bar and fog lamp assemblies
Build and Tag numbers would be required to order
front bar cover
14A1060602P - $1402.50rrp
Lamp driving
12C060603P - $139.13rrp
Lamp Fog
12C060611P - $114.44rrp
Bracket LH
12C060609P - $76.30rrp
Bracket RH
12C060610P - $76.30rrp
Fitting kit
12C060612P - $34.78rrp
Screws (8 reqd)
92138773 - $1.04rrp ea
HSV Rear Lights and assemblies
Tail lamps
12E060605P - $663.00 each
Tail lamp cover (panel where the lights of the other ve's are)
E010606P - $623.22 each
Extension, rear bumper fascia
14A2060606 - $24.48
Guide, rear bumper fascia
14A2060618 - $62.22 each
Exhaust Mounts
Rubber hanger rear pipe (in front of muffler)
22674119
Hanger ASM rear muffler (near outlet)
92066860
V8 dipstick tube (All V8 VEs are the same (inc LS3))
Tube
92067056
Dip Stick
92068536
Seal – Tube Base
24504091
V8 LSD & V6 LSD
Part no ...ratio.......... . RRP$
92157712 3.27 ... HSV..$ 1754.50
92157710 3.70 ... HSV..$ 1974.50
92157704 3.27 ... V6 ...$ 1644.50
92157702 2.92 ... V6 ...$ 2139.50
92157708 3.45 ... L98 ..$ 1754.50
92157714 2.92 ... L98 ..$ 1754.50
92216388 2.92 ... L76 ..$ 1864.50
V8 6.0 Badge Front Guards
92172449 - $11.99rrp
SSV Bodywork
Front grille
92173312 - $60.50rrp
Grille Badge
92172459
Front bumper
Front Right Guard 08-09
92202890 - $275rrp
Front Left Inner Guards (strut tower)
92194554 - $225.50rrp
Front Right Inner Guards (strut tower)
92194555 - $225.50rrp
6 Litre Power steering rack
92207611 - $577.50
6 Litre Radiator
92191918 - $445.50rrp
Bonnet
92193864 - $467.50rrp
Bonnet hinges
92160230 - $14.30rrp
SS side skirts
LHS
92162071
RHS
92162072
SS Foot Pedals
Accelerator
92213647 - $91.85rrp
Brake (Auto)
92173103 - $93.50rrp
Clutch
92173105 - $93.50rrp
Footrest
92164561 - $47.30rrp
V8 clutch cylinder
92067134
Brake Pads (VE HSV)
Front
05A060705
Rear
05B060705
Boot Power Socket Kit
92186334
Maloo Hi-mount stop lamp
12C020501 - $69.48rrp
SS Front Lip Spoiler
GM-92246479
Approx $210
Paint (VE colours bold - please advise of all VE Colours)(touck up paint codes)
15B-950301A1 TOUCH-UP PAINT STORMYGLOW ( ACCENT COLOUR )
15B-950301AE TOUCH-UP PAINT RUBENS RED
15B-950301AH TOUCH-UP PAINT PANTHER
15B-950301AJ TOUCH-UP PAINT LOTUS BLUE
15B-950301AK TOUCH-UP PAINT BOTANICA BLUE
15B-950301B1 TOUCH-UP PAINT HI HO SILVER (HSV WHEEL COLOUR)
15B-950301BJ TOUCH-UP PAINT SILVER MINK
15B-950301BS TOUCH-UP PAINT CHERRY BLACK
15B-950301ED TOUCH-UP PAINT MOR0CCA SAND
15B-950301YM TOUCH-UP PAINT ALASKAN WHITE
15B-950301YN TOUCH-UP PAINT DIABLO RED
15B-950301YR TOUCH-UP PAINT SILVER ICE
15B-950301YW TOUCH-UP PAINT GENISIS BLUE
15B-950301YY TOUCH-UP PAINT SHERBROOKE GREEN
15B-950301YZ TOUCH-UP PAINT MASAI RED
15B-950301ZA TOUCH-UP PAINT HERMITAGE GREY
15B-950301EF TOUCH-UP PAINT ORION SILVER
15B-950301EL TOUCH-UP PAINT TUNDRA
15B-950301ER TOUCH-UP PAINT BERMUDA BLUE
15B-950301ET TOUCH-UP PAINT HERON WHITE
15B-950301FA TOUCH-UP PAINT RAVEN
15B-950301B9 TOUCH-UP PAINT HSV ACCENT GREY
15B-950301AV TOUCH-UP PAINT STING RED ( RED HOT )
15B-950301GI TOUCH-UP PAINT TUNGSTEN
15B-950301GH TOUCH-UP PAINT AMAZON GREY
15B-950301EJ TOUCH-UP PAINT GRANADA RED
15B-950301HN TOUCH-UP PAINT TIGER
15B-950301HZ TOUCH-UP PAINT PHANTOM BLACK
15B-950301KN TOUCH-UP PAINT HACKETT GOLD (SAFFRON)
15B-950301HJ TOUCH-UP PAINT 10TH ANN JAFFA
15B-950301JK TOUCH-UP PAINT GREY STORM
15B-950301LW TOUCH-UP PAINT QUICKSILVER
15B-950301JZ TOUCH-UP PAINT DARK CHESTNUT
15B-950301LK TOUCH-UP PAINT HSV RACING GREEN
15B-950301RP TOUCH-UP PAINT HYPER YELLOW
15B-950301MU TOUCH-UP PAINT YELLOW DEVIL
15B-950301RR TOUCH-UP PAINT DELFT BLUE
15B-950301RO TOUCH-UP PAINT VESPERS BLUE
15B-950301KT TOUCH-UP PAINT SHANGHI RED
15B-950301HG TOUCH-UP PAINT HOT HOUSE GREEN
15B-950301RS TOUCH-UP PAINT MARTINI GREY
15B-950301TG TOUCH-UP PAINT TURBINE GREY
15B-950301BD TOUCH-UP PAINT BERRY RED
15B-950301UV TOUCH-UP PAINT ULTRA VIOLET
15B-950301IP TOUCH-UP PAINT IMPULSE BLUE
15B-950301TU TOUCH-UP PAINT TURISMO
15B-950301KK TOUCH-UP PAINT KAKADO
15B-950301OD TOUCH-UP PAINT ODYSSEY
15B-950301BB TOUCH-UP PAINT BARBADOS
15B-950301IG TOUCH-UP PAINT IGNITION
15B-950301PV TOUCH-UP PAINT PROVENCE
15B-950301SS TOUCH-UP PAINT SANDSTORM
15B-950301RA TOUCH-UP PAINT RED PASSION
15B-950301NI TOUCH-UP PAINT NICKEL
15B-950301EV TOUCH-UP PAINT EVOKE
15B-950301MP TOUCH-UP PAINT MORPHEOUS
15B-950301CR TOUCH-UP PAINT CREMA
15B-950301FU TOUCH-UP PAINT FUSION
15B-950301GL TOUCH-UP PAINT GLAZE
UFO
I Believe
MY10 VE International Sportwagon SIDI 3L
edited:
More Part Numbers
COMFORT ACCESSORIES
HOLDEN ASSIST FLEET VIEW (TELEMATICS) 92215068 $1,446.50
HOLDEN ASSIST ULTRA (TELEMATICS) 92206550 $2,189.00
REAR SEAT ENTERTAINMENT KIT (ONYX, NO SUNROOF) 92198868 $1,754.50
REAR SEAT ENTERTAINMENT KIT (ONYX, SUNROOF) 92198870 $1,754.50
REAR SEAT ENTERTAINMENT KIT (NEUTRAL, NO SUNROOF) 92198871 $1,754.50
REAR SEAT ENTERTAINMENT KIT (NEUTRAL, SUNROOF) 92198872 $1,754.50
REAR SEAT ENTERTAINMENT KIT (NEUTRAL, NO SUNROOF) 92217703 $1,754.50
DVD RF WIRING HARNESS 92202111 $49.50
DVD LAMP PATCH HARNESS (SS&SSV) 92206354 $60.50
DVD LAMP PATCH HARNESS (Calais&CalaisV) 92206355 $71.50
RSE HARNESS KIT 92198869 $93.50
LAMP ASSY - INTERIOR DVD, ONYX 92172665 $49.50
LAMP ASSY - INTERIOR DVD, NEUTRAL 92172664 $49.50
HEADPHONE (QTY 1) 92166141 $82.50
SAT NAV FULL COLOUR MAP SYSTEM 92204197 $1,864.50
SAT NAV CRADLE & HARNESS (- TELEMATICS) 92198865 $121.00
SAT NAV CRADLE (+ TELEMATICS) 92171564 $16.50
SAT NAV WIRING HARNESS (+ TELEMATICS) 92172575 $16.39
SAT NAV MAP DISK 92215886 $555.50
SAT NAV TURN-BY-TURN SYSTEM 92198867 $1,424.50
SCREWS (+ TELEMATICS) 92138633 $1.65
SCREWS (+ TELEMATICS) 92138826 $0.83
GLOVEBOX LINER (+ TELEMATICS) 92173887 $11.00
STEERING WHEEL SWITCH (GREEN) 92194406 $55.00
STEERING WHEEL SWITCH (GREEN) 92194411 $55.00
STEERING WHEEL SWITCH (RED Illum) 92197108 $55.00
STEERING WHEEL SWITCH (WHITE Illum) 92194412 $55.00
FLIP KEY 92193936 $75.90
FLIP KEY TRANSPONDER 92191967 $65.45
MOBILE PHONE MOUNTING PLATFORM (RHD) 92181984 $16.50
Mobile Phone Holder 92143928 $32.45
Harness Assembly - Mobile Phone 92175840 $7.65
POLLEN FILTER 92184248 $26.40
SMOKERS PACK (LEVEL 1) 92189926 $121.00
SMOKERS PACK (LEVEL 2) 92189927 $137.50
SMOKERS PACK (LEVEL 3) 92189928 $137.50
ALARM UPGRADE PACKAGE 92183759 $462.00
BLUETOOTH PHONE KIT 92188775 $324.50
PORTABLE SATELLITE NAVIGATION UNIT 92149160 $649.00
ACCESSORY SOCKET - BOOT 92186334 $32.45
CAR FRIDGE MOUNTING KIT 92190416 $170.50
CAR FRIDGE ASSEMBLY (INC. ALL SUB PARTS). 92217297 $874.50
PROTECTION ACCESSORIES
EXTERNAL
BONNET PROTECTOR 92174817 $88.00
BONNET PROTECTOR 92181999 $88.00
HEADLAMP PROTECTOR 92174815 $82.50
WEATHERSHIELD - STANDARD RH 92174819 $64.90
WEATHERSHIELD - STANDARD LH 92196334 $64.90
WEATHERSHIELDS - SLIMLINE KIT 92174818 $82.50
REAR SUNSHADE - EXTERNAL REAR GLASS 92174822 $93.50
REAR WINDOW DUST DEFLECTOR 92224806 $198.00
MOULDED FRONT MUDFLAP 92179316 $35.20
MOULDED REAR MUDFLAP 92179322 $35.20
INSECT SCREEN 92190655 $126.50
INSECT SCREEN 92190656 $126.50
INSECT SCREEN 92194678 $126.50
INTERNAL
FLOOR MATS - SET OF 4 - ONYX 92179114 $88.00
LUXURY FLOOR MATS - SET OF 4 - ONYX 92179121 $121.00
LUXURY FLOOR MATS - SET OF 4 - LT URBAN 92179122 $121.00
FLOOR MATS - SET OF 4 SS - ONYX 92179117 $107.25
FLOOR MATS - SET OF 4 SS - RED HOT 92179118 $107.25
FLOOR MATS - SET OF 4 SS - IGNITION 92179119 $107.25
RUBBER FLOOR MATS - FRONT 92179574 $49.50
RUBBER FLOOR MAT - REAR 92179582 $43.45
SMALL PARTS KIT - FLOOR MAT RETAINERS (QTY: 2) 92187643 $4.02
BOOT ORGANISER SMALL 92187407 $132.00
BOOT ORGANISER LARGE 92177440 $198.00
Boot Lip Protector 92145973 $55.00
SEAT COVERS - FRONT NON-SS 92186352 $341.00
SEAT COVERS - FRONT SS 92196078 $341.00
SEAT COVER - REAR 92186350 $341.00
SEAT COVER - REAR 92213800 $341.00
SEAT COVER - PET PROTECTION 92186348 $286.00
SEAT COVER - PET PROTECTION 92213799 $286.00
SEAT INSERT - LAMBS WOOL 92190072 $242.00
SUNSHADE KIT - REAR SEAT INTERIOR 92181907 $76.45
CARGO BARRIER MESH - RIGID 92202390 $467.50
PARTITIONING NET 92213801 $330.00
LUGGAGE NET - REAR SEAT BACK 92200548 $71.50
LUGGAGE NET 92168897 $77.00
STRAP KIT - REAR COMPARTMENT TIE DOWN 92176593 $104.50
MOULDED TRUNK LINER 92184706 $154.00
MOULDED TRUNK LINER 92207478 $137.50
MOULDED SPARE WHEEL WELL LINER 92196080 $95.70
MOULDED SPARE WHEEL WELL LINER 92218068 $126.50
SPORTS ACCESSORIES
STEERING WHEEL - ONYX# 92179415 $401.50
STEERING WHEEL - RED# 92179417 $401.50
STEERING WHEEL - IGNITION# 92184788 $401.50
STEERING WHEEL - LIGHT URBAN 92184789 $401.50
LEATHER COVERED GEAR KNOB, AUTO - ONYX 92184832 $75.35
LEATHER COVERED GEAR KNOB, AUTO - LIGHT URBAN 92184833 $75.35
LEATHER COVERED GEAR KNOB, AUTO - RED 92184834 $75.35
LEATHER COVERED GEAR KNOB, AUTO - IGNITION 92184835 $75.35
LEATHER COVERED GEAR KNOB, MANUAL - ONYX V6 92184842 $122.10
LEATHER COVERED GEAR KNOB, MANUAL - RED V6 92184839 $122.10
LEATHER COVERED GEAR KNOB, MANUAL - IGNITION 92184840 $122.10
LEATHER COVERED GEAR KNOB, MANUAL - ONYX V8 92184841 $122.10
LEATHER COVERED GEAR KNOB, MANUAL - RED V8 92184837 $122.10
LEATHER COVERED GEAR KNOB, MANUAL - IGNITION 92184838 $122.10
CHROME HANDLE RH FRONT INTERIOR - ONYX 92186978 $82.50
CHROME HANDLE LH FRONT INTERIOR - ONYX 92186979 $82.50
CHROME HANDLE RH REAR INTERIOR - ONYX 92186982 $82.50
CHROME HANDLE LH REAR INTERIOR - ONYX 92186983 $82.50
ALLOY PEDAL - ACCELERATOR 92165105 $143.00
ALLOY PEDAL - BRAKE AUTO 92173103 $93.50
ALLOY PEDAL - BRAKE/CLUTCH MANUAL 92173105 $93.50
#Note: OMEGA Steering wheel upgrades require additional parts
ROOF RACKS
ROOF RACK - SEDAN 92174445 $385.00
ROOF RACK - WAGON 92207466 $385.00
Roof Rack Tray 92165757 $715.00
ROO BAR - Black 92179350 $1,094.50
NUDGE BAR - BLACK 92179351 $775.50
Ski Carrier (Universal Type) 92165759 $65.45
Ski Carrier (Scissor Type) 92166679 $233.20
Bicycle Carrier 92199529 $262.90
Roof Storage Pod 92177448 $803.00
STYLING ACCESSORIES
DECAL KIT (BLACK) 92190422 $302.50
DECAL KIT (SILVER) 92190423 $302.50
DECAL KIT (BLACK) 92216686 $335.50
SPOILER KIT 92178342 $324.50
BODY KIT SIDE SKIRT LH 92187670 $126.50
BODY KIT SIDE SKIRT RH 92187671 $126.50
MOULDED FRONT MUDFLAP FOR BODYKIT 92179318 $35.20
DRIVING LAMP HARNESS 92213062 $159.50
DRIVING LAMP PACKAGE - RECTANGULAR 92146715 $192.50
Exhaust Extension Chrome 92055420 $36.58
WHEELS
CENTRE CAP, BRIGHT CHROME LION & RING - GRAPHITE 92156262 $34.65
CENTRE CAP, BRIGHT CHROME LION & RING - DARK ASH 92173171 $22.00
CENTRE CAP, BRIGHT CHROME LION & RING - GREYSTONE 92092761 $20.90
CENTRE CAP, SATIN CHROME 92085477 $41.25
LOCKING WHEEL NUTS 92190654 $60.50
LOCKING WHEEL NUT CAPS (ALLOY WHEEL SILVER) 92182100 $2.75
LOCKING WHEEL NUT CAPS (BLACK) 92182099 $2.15
LOCKING WHEEL NUT CAPS (CHROME) 92182001 $3.25
SAFETY PRODUCTS
First Aid Kit 92175820 $40.98
Safety Triangle Package 92140069 $46.75
Safety Jumper Leads 95710075 $69.30
REAR PARKING SENSOR KIT - HERON WHITE 92199530 $429.00
REAR PARKING SENSOR KIT - RED HOT 92199531 $429.00
REAR PARKING SENSOR KIT - IGNITION 92199532 $429.00
REAR PARKING SENSOR KIT - PHANTOM 92199533 $429.00
REAR PARKING SENSOR KIT - PROVENCE 92199534 $429.00
REAR PARKING SENSOR KIT - EVOKE 92199535 $429.00
REAR PARKING SENSOR KIT - SANDSTORM 92199536 $429.00
REAR PARKING SENSOR KIT - RED PASSION 92199537 $429.00
REAR PARKING SENSOR KIT - VESPERS BLUE 92199539 $429.00
REAR PARKING SENSOR KIT - NICKEL 92199540 $429.00
REAR PARKING SENSOR KIT - IMPULSE II 92199541 $429.00
REAR PARKING SENSOR KIT - ODYSSEY 92199542 $429.00
REAR PARKING SENSOR KIT - MORPHEOUS 92199543 $429.00
REAR PARKING SENSOR KIT - VOODOO 92226197 $429.00
REAR PARKING SENSOR KIT - NITRATE (SWITCHBLADE) 92226198 $429.00
REAR PARKING SENSOR KIT - KARMA 92226196 $429.00
TOWING ACCESSORIES
1200KG
TOWING PACKAGE 1200 KG - LESS HARNESS 92175160 $253.00
TOWBAR - SMALL PARTS KIT (1200KG) 92187352 $76.45
2100KG
TOWING PACKAGE 1600/2100 KG - LESS HARNESS 92196009 $352.00
TOWBAR - SMALL PARTS KIT (1600/2100KG) 92196008 $87.45
TOWING PACKAGE 1600/2100 KG - LESS HARNESS 92207452 $352.00
Equaliser Hitch - 2100kg 92140101 $495.00
TOWBAR TONGUE KIT (CLASS 2) 92187353 $25.85
TOWBAR TONGUE ASM (CLASS 4) 92187354 $28.05
TRAILER WIRING BRACKET (ALL) 92191958 $16.50
PIN & CLIP TOW BAR 92187355 $9.85
D SHACKLE 92191960 $6.55
TRAILER HARNESS - 7 PIN FLAT 92218770 $79.75
TRAILER HARNESS - 7 PIN FLAT 92218768 $121.00
ELECTRIC BRAKE KIT 92174824 $478.50
Trailer plug Adaptor - (7 pin flat male / 7 pin large round female ends) 92147323 $21.89
Trailer plug Adaptor - (7 pin flat male / 6 pin round male ends) 92147324 $21.89
Trailer plug Adaptor - (7 pin flat male / 7 pin round male) 92147325 $21.89
Towing Mirror Clip on 92142800 $39.33
Tow Ball - Chrome 95710077 $23.10
Tow Ball Cover 95710076 $4.95
REAR FASCIA ESCUTCHEON - TOWBAR 92186336 $13.09
REAR FASCIA ESCUTCHEON - TOWBAR 92186338 $13.09
REAR FASCIA ESCUTCHEON - TOWBAR 92186340 $13.09
Glovebox light wiring loom - 92172575 - $17.30
2010 VE SS special edition with G8 hood.
Rubber underhood bumpers.
Front 3 Push-in 92161661
Rear 4 Adjustable Screw-in 90054143
VE V8 Automatic Transmission Cooler Kit:
10385350 Cooler ASM - $265 +GST
92235999 Pipe ASM- Trans $125 +
92229556 Bracket-Trans F $7.80+
92229558 Bracket Trans F $7.80+
92196369 Bracket Trans TRA - $22.25 +
24205103 Retainer OI $14.60 +
92218904 Pipe ASM- Trans $73.50+
N.E. Vic
great post mate.
are these rrp's AU? (ie is website source from australia)
Hi, I believe they are Australian RRP prices. Not sure how accurate they are. Best to get an up to date quote from your local holden dealer in any prices. The website was another Aussie commodore forum. Unforunately this forum has blacklisted the url.
57chevvy
57chevvy
61
Dwellingup / Western Australia
2008 VE 6.0 Litre SS Commodore
Touch up paints
I didn't see the number for Wildfire in your list. This colour was a test colour that Holden brought out in 07/08 in the V6 band V8. There were only ten cars in Australia of this colour at the time and only one was in W.A which i own.
Richard
jace75
JULY 08 VE SSV 60th Anniv.
or the touch up paint for Nitrate 08 60th anniversary ssv
Azza SS
NT
VE 6.0ltr SS SportsWagon
Very handy to know whats out there, thank you
SINSTR6
VE SV6 SPORTWAGON
WA
VE SV6 SPORTWAGON
GXP Front Brake Parts
92221882 Front Caliper
92221883 Front Caliper
92213817 Rotors LH and RH
89047725 Brake Pads
The Caliper Number im not sure whats left or right.
Apparently from the G8 Forum the Brake lines from the standard brakes work on these calipers.
Zerone_V
Lexus IS350 (SL)
Information for Holden Power Window Switch 4 Window (Piano Black)
Power Window Switches for 4 Window Vehicles.
Piano Black Finish, as fitted to SV6, SS and SS-V Models.
White Button Illumination, Auto Window Down and Up Model.
Part Number: 92247220
Manufactured By: Holden
Category: Interior Electrical
Availability: Rare
Information for Holden LHS Steering Wheel Applique (Micro Silver)
Steering wheel plastic applique Left Hand Side,
Micro Silver colour, as fitted to HSV E3 Models (And possibly many others). Can be fitted to all non Omega Models.
Omega models require a different steering wheel to fit.
Part Number: 5002443
Category: Interior Trim
Availability: Common
HSV E3 Steering Wheel Controls information
Information for Holden Special Vehicles HSV E3 Steering Wheel Controls
Steering Wheel IQ Controls for E3 Series HSV Models. Includes EDI, NAV and Bluetooth Buttons.
Part Number: 5003140
Manufactured By: Holden Special Vehicles
Category: Interior Audio
Availability: Rare
The Light switch and the stock piano black steering wheel switch part # I dont have...
Taken from
www.carmodder.com • Search Vehicle Parts
