Calais57
Donating Member
- Jan 29, 2009
- 196
- 4
- 18
- Location
- Blue Mountains, NSW
- VE Calais V 6.0
Hi everyone,
I am surprised I haven't seen this mentioned here before and apologies if it has (in which case just ignore my thread).
On a couple of the USA G8 forums it is a regularly posted topic, so its not my own idea. I must admit I have been sceptical and have not done it to my Calais but will now do so after a friend did it to his VE SSV over the weekend.
The first improvements are well known:
1. disconnect centre dash speaker
2. turn up the gain on the small amp in boot.
But the biggy is:
3. reverse the +ve and -ve wires on each of the two subs in the rear shelf. This can be done easily with a soldering iron in the boot under the parcel shelf (just dont drop solder in your eye!! lol).
This makes the two subs pump the wrong way (ie down, not up into the cabin). But the theory goes something along the lines that the subs with normal wiring seem to "counter" or cancel out some of the other speaker sound. With this mod they no longer do so.
I have almost zero knowledge of sound system theory and this seems weird but it really does work!!
It would still not be good enough for the big sound system boys and girls, but does make a very big (seriously) improvement.
I wish I knew about this before replacing my door speakers and the subs with 8" kickers!! Anyway I will now reverse the wiring on the kickers just for fun to see if it also makes such a big improvement to aftermarket shelf subs.
Hopefull combined with my better quality door speakers and the Dynamat I have used around the rear shelf, it will add up to something better than acceptable.
It will be a couple of weeks before I can do this, but will let you know how I go.
Calais57
But the biggy is:
Calais57
