VE R8 HSV headers and cats on WN caprice-V?
Discussion in 'VF Holden Commodore (2013 - 2017)' started by vol800, Jul 14, 2015.
  1. vol800
    vol800 Vader
    WN Caprice-V
    hey all, after 3 year hiatus...I'm back into a 6litre and back to fiddling with minor subtle mods..it's a 2014 caprice v fitted with a catback hm header 2.5" and a walky CAI. Have the opportunity to pick up some R8 HSV headers with cats...(orginally from a 2012 r8) cheap. I dont mind skinning some knuckles to get them on but does anyone know if they should bolt straight up onto the wn caprice? Any advice gratefully recieved...
    VXBaz likes this.
  2. vol800
    vol800 Vader
    WN Caprice-V
    hmmmm no one? OK, I took a punt and grabbed a set pretty cheap set from off fleabay.. I saw someone had fitted them to a WM Caprice so I figure I'll roll the dice. As soon as I fit them up I'll update just in case it helps someone else- with 130 views of this thread to date and no takers- there must be some interest in doing it...
    VXBaz likes this.
  3. ozNick
    ozNick Active Member
    2007 VE Calais V L98, Lexus LX470
    In the VE (and I presume WM) the HSV headers and cats can be a direct swap out for the stock exhaust manifolds and cats.
    Lots of threads in here on how to do it.
    I for one would like to hear how you go. My HSV headers and cats are on the back porch for now.
    VXBaz likes this.
  4. villn808
    villn808 Active Member
    Melbourne, SE Suburbs
    MY15 SSV Sedan
    I fitted VE GTS headers and cats to my VF, but it's an SSV.
  5. dgp
    dgp Well-Known Member
    VF II SSV Redline
    I think people view because they are interested.
    Because the Caprice is LWB, the exhaust systems are longer than the sedan range but I would think headers and cats would all be the same part and the cat back section would be different.
    End of the day I don't know though. Would like to know how you go for interest sake.
  6. SnowDoggyDogg
    SnowDoggyDogg 2ltr? = Only milk & juice
    Goldie
    Gen F GTS
    The cheats way might be to take a look at a few exhaust brands online that sell headers and cats that bolt right up to a stock VE/VF catback (think Pacemaker stubbies do?). If they also say WM/WN then you've got your answer.
  7. lmoengnr
    lmoengnr Well-Known Member
    Sunbury Vic.
    MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
    They will bolt up just fine. The ute and the Caprice use the same mid section, and same mufflers, but MY12 utes have changed rear hangars on the R/H muffler.
    VXBaz likes this.
  8. vol800
    vol800 Vader
    WN Caprice-V
    OK, they did bolt up just fine- even squeezing in past the steering linkage. Now that they are on..I haven't had a chance to give it a healthy 'off the line' to 'feel' any difference as it's too wet in Melbourne today. From a sound perspective....there is a difference, I think it's a tiny bit deeper but honestly hard to tell. I think it sounds like it's 'pulsing' better throughout the system (benefit of the HSV tri-y?) but again, maybe my ears are straining to hear what I want to hear..still, the exhaust note has changed slightly... It wasn't worth paying for a dyno run before/after so unfortunately any feedback I give (like aural opinion) will be subjective.... If it honestly feels different under heavy acceleration (low end I'm guessing) and if there is any improvement to fuel economy I'll update.
    VXBaz likes this.
  9. VXBaz
    VXBaz Member
    2004 VY Series II Wagon
    It's been a while since you did this. Today I was searching for "WN Caprice mods" and came across your thread (so it's helping me - thanks). What was your eventual conclusion?
    Mine is an almost new Series II 6.2 so would I be able to do the same mod? I'm guessing yes. I'm looking for a way to get a "bit" of extra "something" from the sound. Mine will be a working car so it can't upset any of the Opera goers but I would like to get a little extra V8 presence as the stock system is practically silent.
    I've been next to a grange and a GTS at the lights as they took off gently and although not too loud I can see that a full GTS/R8 style system might be too loud for the "Festival set" but I'm going to drive this car all day every day so I need something to keep me happy. Would love to hear an update. Thanks for the thread.
  10. dans_vz
    dans_vz Active Member
    Albury
    MY16 VFII SSV Redline Manual & 05 VZ Calais daily
    Yes they will fit on your series 2. I've got a set for mine but haven't had a chance to fit them yet
    VXBaz likes this.
  11. VXBaz
    VXBaz Member
    Thanks. I'm assuming the engine bays of a Caprice and a commodore are identical with just the "after cat" length being longer in the Caprice?
  12. lmoengnr
    Sunbury Vic.
    If the HSV system 'too noisy':D, get a pair of bi-modal valves for the mufflers.
    Just keep the valves closed when the 'opera goers' are on board.
    VXBaz likes this.
  13. VXBaz
    VXBaz Member
    Sounds like a great solution. Thanks for the suggestion.
    lmoengnr likes this.
  14. Justin Rayner
    Justin Rayner New Member
    Penrith
    Wm caprice 2008 6 litre
    Does anyone know. Would the rear mufflers from a ve gts fit a wm caprice?
  15. abuch47
    abuch47 Active Member
    Madelaide
    LSS3 YOOTE
    Should do the sedan wheelbases are different but that should only affect the mid section not rear mufflers.
    e series gts has staggered outlets dont think the WM did so may not clear rear bar but will "fit"
