VE Remote HELP!
Discussion in 'VE Holden Commodore (2006 - 2013)' started by montanainc, Apr 13, 2011.
  1. montanainc
    montanainc New Member
    South Australia
    VE Calais V
    Hey guys recently purchased a second-hand ve calais v, great ride real happy and glad have found this great forum
    Got both sets of flip keys from the seller but noticed one of them wasn't working, thinking it must have just been a flat battery.... other was working so it wasn't an issue
    But finally got around to getting the battery changed and the bastard still won't work, I've opened it up and can't see anything standing out that might be the cause.... any ideas??
    Thinking it may be a board issue.. if so is this something a Holden maintenance can fix easily and hopefully minimal cost....?
    Any help would be greatly appreciated
  2. SV8
    SV8 New Member
    MT Gambier SA
    VE SS & VN Clubsport
    the remotes arnt that dear to buy $60-$70 (we sell them where i work) when i bought my ss it only came with 1 standard key, So i bought the flip key and had that programed in
  3. Jebadayah
    Jebadayah New Member
    VE SV6
    My car only came with one key also...cost me almost $300 for a replacement through holden :(
  4. jasonsv6
    jasonsv6 New Member
    berwick
    2010 SR POS
    is it the remot part that wont work or the imobaliser side of things
    the coading for the remote is different so if the buttons dont work try starting the car with it.
    because the imobaliser chip is in the flip part of the key. you may find that this still works and the buttons a simply stuffed.
    if it also wont start the car then holden can programme this for you for about $120
  5. montanainc
    South Australia
    VE Calais V
    I can start the car with the key but the buttons don't work for locking/unlocking or oening the boot
    Might just take it in and see what they say but yeah if it's gonna cost hundreds I think I'll leave it...
  6. Super_Low 91
    Super_Low 91 ┌∩┐(◕_◕)┌∩┐
    Aussie
    Not a Commodore
    if the transponder side is working eg starting the car no worries then it is the remote witch you can get from Holden separately, as for the price im not to sure sorry, I know the complete keys up here are around the 400ish mark
  7. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 6.0 470rwhp
    May just need to be recoded to the car..
  8. jasonsv6
    jasonsv6 New Member
    berwick
    2010 SR POS
    i would think the same as ricey here if the battery has been flat for some time then the coding might be lost.
    im not 100% but im pretty sure theses keys work on a rolling code of sorts so a simple rematch to your car and you should be right.
    if the buttons are cactus you can buy them of ebay cheap as. you can even buy any other used commy key flip and non flip heads are the same. then have that coaded to your car.
  9. RiCeY
    Australia
    You can buy the genuine buttons on their own from Holden fairly cheaply...
  10. 316
    316 Computers
    VE Series II SV6
    yup, apparently you have a limited time in which to swap out the battery otherwise the coding is lost.
    This was for a suzuki, but same deal goes for holden.
    Also, put the battery in the right way. I didn't, and apparently my key is stuffed because of that.
  11. montanainc
    South Australia
    VE Calais V
    Cheers for the help lads
  12. SV6.07
    SV6.07 Donating Member
    Melbourne,Victoria
    2007 VE SV6 Nitrate & 2011 VE SV6 Poison Ivy
    go to holmart.com.au he can help you with the section with the buttons. and also flip or standard. would be able to even let you try a new section on ur key to make sure all works.. have got helps from these guys.
    8 EBDEN STREET
    MOORABBIN,
    MELBOURNE,
    VICTORIA, AUSTRALIA, 3189
    PH 03 95321817 FAX 03 95321213
    e-mail Sales@holmart.com.au
