Ve repair manual.
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Nuffsed, Mar 5, 2020.
  1. Nuffsed
    Nuffsed New Member
    NT
    VE Calais Sportswagon 08 LY7
    I have a pretty comprehensive manual on Ve. I won't name the publisher.
    If you need anything from it like schematics and stuff me know and i'll up the info you request.
  2. mechanic
    mechanic Active Member
    Australia
    Commodore
    Does it have have different VIN breaks throughout the years? There were many changes through both of these models, a manual that covers lots of variants could be misleading.
    Stick with OEM manuals where you can.
  3. Nuffsed
    Nuffsed New Member
    NT
    It covers alot of the Vf as well as the Ve. But ill edit the title and won't upload any Vf related stuff as it may confuse people.
  4. mechanic
    Australia
    Commodore
    There were also wiring diagram changes every year for the VE model. One manual won't cover all year models.
    My point is: be cautious unless it's an OEM product.
  5. Nuffsed
    Nuffsed New Member
    NT
    This is way more comprehensive than anything else i have found online and it's from a reputable author on car manuals.
    I only put it out there as it may help someone that might need it. That's was the aim. No one has to request anything but the offer is there.
  6. Fu Manchu
    Fu Manchu Well-Known Member
    WA.
    Slug powered VZ, a VE Calais & your mum.
    The factory service manual is available as a download. There is a link here on the forum.
  7. Nuffsed
    Nuffsed New Member
    NT
    I have that as well. They can use both. Can never have enough information.
    VS_Pete and Fu Manchu like this.
  8. SWK
    SWK New Member
    ve lumina
    Hi, I have a VE Lumina 2007 and for some reason the parking lights are not working. I believe it has been disconnected during a repair job but the repairers does not want to look at it. In short, I need a wiring diagram of the wiring loom involved. Can you help?
  9. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
  10. Fu Manchu
    WA.
    You have checked the globes? Fuses?
  11. Apw
    Apw New Member
    2011 VE Commodore Sportwagon
    Have you got a link to download the one on the forum
  12. SWK
    SWK New Member
    ve lumina
    Hi, I have checked all that I can, I have power to the fuses +side on F42 and F43. I have tested the relay which supplies the two fuses.Rear Parks works fine but the two front parks are dead. Power leaves the fuses but does not appear at the connection point to the headlights and parkers. I am at a loss as to the path the loom takes. A wiring diagram would help.
  13. Fu Manchu
    WA.
    You need this:
    https://drive.google.com/file/d/0B4Fgnxs7df80ZjBsamhhSm1DaEE/view
    Source: Go to this link in the forum.
    https://forums.justcommodores.com.au/threads/ve-commodore-workshop-manual.249815/#post-2789170
    It is the genuine Holden manual. It will take time to navigate it at times.
    You need to have the menu side bar to do that.
    Links won't work unless you are connected to Holden Intranet.
    To find links, use the search/find function.
    Grabbing a wiring diagram isn't like it used to be in a Haynes Manual.
    Alternatively there are individual files available here:
    http://www.mediafire.com/?6l6q10bav0xof
    However they are for US models and may only serve as a guide for right hand drive Aussie models.
    rucxy likes this.
