Ve repair manual.
Apw
62
2011 VE Commodore Sportwagon
I have that as well. They can use both. Can never have enough information.
Have you got a link to download the one on the forum
SWK
ve lumina
You have checked the globes? Fuses?
Hi, I have checked all that I can, I have power to the fuses +side on F42 and F43. I have tested the relay which supplies the two fuses.Rear Parks works fine but the two front parks are dead. Power leaves the fuses but does not appear at the connection point to the headlights and parkers. I am at a loss as to the path the loom takes. A wiring diagram would help.
Fu Manchu
Get off your phone when you’re driving.
Western Australia
Kia Sorrento, VZ Crewman, VZ Cross 8, & ya mum.
You need this:
https://drive.google.com/file/d/0B4Fgnxs7df80ZjBsamhhSm1DaEE/view
Source: Go to this link in the forum.
https://forums.justcommodores.com.au/threads/ve-commodore-workshop-manual.249815/#post-2789170
It is the genuine Holden manual. It will take time to navigate it at times.
You need to have the menu side bar to do that.
Links won't work unless you are connected to Holden Intranet.
To find links, use the search/find function.
Grabbing a wiring diagram isn't like it used to be in a Haynes Manual.
Alternatively there are individual files available here:
http://www.mediafire.com/?6l6q10bav0xof
However they are for US models and may only serve as a guide for right hand drive Aussie models.
anthony09
37
Kelmscott
Ve Omega
Would u have the pages to change the timing chain or mainly the torque specs for main things if possible plz
Fu Manchu
Western Australia
As outlined in the previous post, download from the above links. Enable the side bar in the pdf reader and use the navigation menu in the side bar to go to the timing chain info.
