VE Rims on a VZ
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Whitesack07, May 1, 2011.
  1. Whitesack07
    Whitesack07 Member
    Grafton
    VX S
    Hey guys, what needs to be done to fit a VE rim onto a VZ? i know you gotta do something but not sure what it is.
    cheers
  2. Sabbath'
    Sabbath' Redblock Jesus
    80 Series// MK5 GTi//
    The centre hub of the rim needs to be machined out to fit.
  3. Zeussy
    Zeussy SSM11K
    Central Coast
    Gen-F Clubsport, Rodeo 2.8 TD 4x4
    Apparently the studs are thicker on the VE aswell, so you either need wheel nuts with a larger taper/surface area to get a good hold on the rims. or some sort of sleeve to suit..?
    Lost of people just run standard nuts, and get away with it, but if ever I run VE rims on anything pre VE, I'd be looking into that also.
  4. Whitesack07
    Whitesack07 Member
    Grafton
    VX S
    Thanks for the help guys, so if i get VE rims for my ute i would need to get them machined out to fit an get nuts with a bigger taper/surface area? so would nuts off the ve rims be ok?
  5. Zeussy
    Zeussy SSM11K
    Central Coast
    Nah, nuts off a VE would be no good, because they run a thicker stud - the nut would just slide over the studs, not screw onto it ;) lol.
  6. Whitesack07
    Whitesack07 Member
    Grafton
    VX S
    ok thanks lol, i dont know much about the rims an stuff with them lol, i just want some ssv rims but had no idea what needed to be done, i knew i had to get something done lol
  7. Zeussy
    Zeussy SSM11K
    Central Coast
    lol, sweet as, post pics if you do go down that path :thumbsup: :)
  8. Whitesack07
    Whitesack07 Member
    Grafton
    VX S
    yeah i will post Pics on my thread if i go down that path, im pretty sure i will, i dont like my 19's an i dont wanna go bigger, i love the vy sigs but they cost so much, so ssv's it is :)
  9. one_and_only2004
    one_and_only2004 Turbo L98 FTW
    Regional NSW Australia
    Z Series Thunder Utility - Turbo
    You don't really need different wheel nuts, all you have to do is make sure you locate the wheels perfectly onto the studs - this means no air tools for doing up nuts.
    I never had a problem with my SSV rims on my VY - they looked awesome too!
  10. Whitesack07
    Whitesack07 Member
    Grafton
    VX S
    Nar i dont have a air gun to do up the nuts, i dont like using them, an they look nice i think they are one of the best rims that holden have made
  11. DAZ88P
    DAZ88P Member
    Caringbah, Sydney
    VZ Berlina
    I took my nuts off my standard berlina alloys to test it on my VE wheels before i put them on and the taper from the nut fits the VE alloy fine.
    Think the nut issue got brought up by people using the same nuts as used on their steel wheels for an alloy.
  12. Whitesack07
    Whitesack07 Member
    Grafton
    VX S
    ok thanks heaps for the info guys, now i just gotta get the money for the SSV's :D
  13. Zeussy
    Zeussy SSM11K
    Central Coast
    Could quite possibly be the case, I've never actually looked into it further than what I've heard online...
    Sounds pretty believable but, the alloy wheel nuts have a pretty big shoulder on them in comparison to the steel wheel nuts. :)
