VE S2 IQ Facia
Fu Manchu
WA.
Looking to double check if the facia for the IQ is ok to swap with another?
Our is playing up a bit.
I know the IQ head unit has to be linked to the car.
Is this link in the headunit or the facia (which unclips from the head unit)?
Ping @TazzI
Fu Manchu
WA.
I have a facia with some dodgy volume controls.
I also have a facia with a damaged exterior but the knobs turn nicely.
I have stripped down the damaged facia and the board that control volume and climate are marked with the same codes.
Marked as 321 Variant on the board. Same barcodes as well.
Can I swap that part of the board over without any hassles?
Skylarking
123
Downunder
Commodore Motorsport Edition
Don’t know about iQ or VE programming but unless the facia is a separate programable object within Holdens service system, I doubt it’s locked to a specific VIN. And if the facia is common across models and also provides a common feature set, then that would probably support a view that it is not programable.
So, without knowing how much effort it is to remove the facia, maybe just a tug and it pops out, why not simply try swapping the parts and then installing the repaired facia to see if it works?
Fu Manchu
WA.
Well I’m putting the car back together (slowly-time poor) after doing the evap, heater core, interior panels, brake mod plate, engine bay, inlet manifold.
I’m not keen to fiddle with anything just now because pulling that much wiring out makes me anxious about having everything work ok.
I might leave the exterior trim off so I can pop the facia off ok. If all works it’s easy enough to get that panel off and replace it. Then see if it’s ok. If not I’ll swap back.
Fu Manchu
WA.
So I figured this myself and I'll share what I learnt.
The facias are interchangeable, as far as they aren't matched to the head unit.
No programming required.
My issue. A dead pixel on the screen.
Iffy volume control. Have to turn the knob slowly.
So I got a hold of a spare facia. It had been forced of the headunit. It had screwdriver marks and bent plastic mounts.
I plugged it in (finally got the power sorted to the car) and everything worked.
The screen was good.
All the memory for the stations and settings is stored in the head unit, not the facia. Everything came up the same.
The volume controls and station tuning was cactus on the spare I bought, so an easy answer there. Make do with what I have.
I did swap out the screen. Both circuit boards were marked as the same level, with the same level codes.
Fu Manchu
WA.
The back of the unit. This one is minus the screws. T-6’s.
Fu Manchu
WA.
The screen and its boards are held in by the retaining screws that hold the metal cover. The others you see don’t need to be removed.
There are two tabs you need to release marked with the giant novelty arrows.
Then use a small flat blade to gently lever up the outer boards. Leave them connected.
Fu Manchu
WA.
Oh, first unscrew the bottom metal cover. There are two ribbon connectors attached to dont pull it away. Tilt it toward you and it fits into a slot in the upright position. Gently lever off the beige retainer. Super gently as if it were the soul of a unicorn.
Then you can carefully remove the ribbon connector/cable thing. Leave the main board connected if removing the screen only. Other wise repeat the procedure and carefully remove the lower board as well.
That has the HVAC stuff as well as the stereo knobs.
Fu Manchu
WA.
Slot the ribbon connectors back in ever so gently. Use care, as if you have the trots and need to move swiftly. That kind of care.
Oh and to remove the four screws on the lower board near the knob circuits. 2 each side if you are replacing the hvac controls.
wetwork65
A wet business
VF SSV Wagon & VF SV6 Wagon
Great writeup. Thanks.
