2010SSVREDLINE
- Apr 10, 2022
- 17
- 4
- 3
- Age
- 32
- Location
- Perth
- VE SERIES II REDLINE
L77 mateyI honestly don't think he'd even know...
Hey mate, have you read the posts thoroughly? Recommended upgrade everything, get rid of dod/ performance upgrade jt, nothing heavy, just mild performance , cam etc, brand of choice from service 2ic HarropYeah and don't reckon I'd be paying $130 an hour to have it torn down only to find out it's too expensive to fix. I'd be talking to the supervisor and seeing what deal they can do on a crate engine. No doubt Holden Service and Spares can buy one cheaper than we can.
Yep been trying to keep up with most of the thread. Have you been given a quote to do all this work, or have I missed that part?Hey mate, have you read the posts thoroughly? Recommended upgrade everything, get rid of dod/ performance upgrade jt, nothing heavy, just mild performance , cam etc, brand of choice from service 2ic Harrop
Or cause damage to a wiring harness, unless it was 400mls per week, for 12 months...I really doubt loss of 400mls would cause pushrod or cam damage.
Yep. They are not cheap anymore. They are not plentiful. They are a superseded motor now that GM make the LT. (If they still make that?)Wow, only $19K for a crate engine. Comes exactly as pictured with flywheel and clutch.
[/URL]
I really doubt loss of 400mls would cause pushrod or cam damage. Hitting the rev limiter (due to electrical fault) may indeed cause such damage.
The issue as I see it is why didn’t the dealer service indemnify the pushrod, cam and follower issues and simply settle on the loom and I think later the ECU? Surely all damage that occurred should have been able to be identified by their experts, especially if OP indicated the engine was bouncing off the rev limit at the lights without accelerator input
To me it seems poor service standards may be partly at play. Harness oil damage is a long term thing and doesn’t occur from just one incident. Interestingly GM’s global recommendation (is for harness repair rather than costly replacement but I guess that Holden dealer doesn’t read Techline Connect and missed that article…and probably an associated service bulletin.
We already suspect the dealer profited by changing a key/lock when it seems like wasn’t really required, so what else have they been doing to profit at tne expense of the OP?
Time will tell where this ends up but I wouldn’t be holding my breath or going back to that dealer and paying them for any repair.
To me that dealers behaviour seems less than honourable by having the OP’s car off the road for so long (10 weeks) when a suggestion of a second hand loom from a wrecker would cost bupkis, resolved the problem (atleast part of it) and seen him back on the road much sooner saving him considerable hire car costs. But they wouldn’t have gotten the markup on that new loom and ECU…
Interestingly, when I bought my Holden, the first visit at the dealer saw an old bloke being explained why he needed to spend $$$ on his stretched V6 chain. The only missing bit of the explanation being that it’s a known defect and that it should have been repaired gratis by Holden. Really, let’s not forget dealer service can be laying self serving cnuts.
Some dealers have integrity and provide good service but they seen the exception to the rule of screwing the customer
What it is that I want; a Second optioned, parts that have been removed by mechanic to be inspected, old harness inspected etc. I want to know what has caused the issue, not blame somebody else for “driving with low oil” which DID NOT HAPPEN. the service 2ic, said only 400ml was LOST from the motor, out of the entire tank full. Car was stilll in “serviceable” amounts when it went in with the first initial problem. Stop saying I drove it with low oil. This DID NOT happen.
