1991_Vn2nV said:
172kw version gets 11.0l per 100km compared to 11.4l for the 190...
And do you think they redline the engines when they are testing fuel consumption....i dont think so. 1500-3000rpm is exactly the range they would test.
Why would they put a diesel in it? You're gonna be a very long way away from 190kw if you're using a 3.6litre diesel engine...
Diesels only have ONE upside...and thats fuel economy. For a start, diesel engines have lower rpm ranges and less power, they are normally more expensive...they have incredibly high compression ratio's, they are a heavier engine, they smell like **** and who wants to buy a new commodore if its gonna be leaving a 10km trail of smoke in a few years?, they're harder to start when its cold, and they are noisier and not as smooth.
Mmmm sounds like a great idea to shove a diesel in a VE Commodore....
Obviously you haven't been near a diesel engined car since the Diesel Gemini!!!!
Diesels have many many advantages. 1 litre of Diesel fuel has more energy in it than 1 litre of Unleaded.
Most people have the same thinking as you. kW's is not the important number, sure its great, but its Nm of torque that is the important figure.
In gear acceloration is muuch better in a diesel than in an inquivelent sized petrol engine.
Check out the new Astra diesel, wheels mag said they would pic the Diesel over the SRi Turbo petrol!!!!!!
Petrol : 147 Kw 250Nm
Diesel: 110kW 320 Nm
I know which i would prefer.
Go take the diesel Astra for a test drive, and realise that what your talking about in regards to lack of power, smell, noise, harshness ect is all rubbish.
Diesels usually suffer from these things because they aren't serviced correctly.
Go on, go for a drive, you will be suprised!!!
