VE Series 2 Head Unit fuse
Duff8616
VE Commodore Ute
In the process of installing an Amp in my VE Ute, After connecting it all up the Head Unit wont power on. Air con still comes on but is unadjustable. Thinking it may be a blown fuse but all of the fuses in the fusebox are good. Is there a separate fuse for the head unit I can check?
Adrian's Vr
22
Vr commodore manual
Any updates on this?
LincolnDavis10
21
Ve ute s2
I’m also experiencing the same issue, any help would be greatly appreciated. Cheers
Adrian's Vr
22
Vr commodore manual
it was the plug to the head unit, if u can wiggle the plug even slightly then its not on correct, make sure u really go down in personal and align the dickies with the plug lever, yes it's difficult
SamiB
34
Rockhampton
VE SS Z series
I Have the same issue but no SS instal but has been done on mine
Mine in occasion once started sets its self to ‘foot vents option’ and won’t allow it to b changed to another selection.. have to turn off the car and re start for this to disappear
cliftondavid01
60
happy valley
ve commodore ute
What was the fix here?
Fu Manchu
WA.
From time to time the headunits will do this.
•Pull the fuse in the boot above the battery.
•Leave it for a few hours.{or overnight)
•Reinstall the fuse.
•Ignition on.
•Headunit facia powers up.
perth
vz commodore
yep had same problem this morning this is my fix
turn key onto on position koeo (key on engine off)
open boot look for rectangular fuse box above battery
(battery is left hand side in the boot) open the box
look for the 15 amp fuse on the far right 2nd one down
from top pull out for a few seconds then reinstall
raio facia info screen worked
