VE Series 2 Key Issues
Vs-AclaimII
Ve Series 2
Hi all,
So, my issue now is, ever since, I've replaced the shell on my flip key, I changed the blank key and installed the key from my old flip key. And now the car won't start. I've tried to re-program the key however no luck at all. Any thoughts on how I would overcome the barrier?
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
There will be a transponder chip somewhere in the original shell, that needs to be in the new shell.
There are threads in the VE forum about this. Do a search.
Vs-AclaimII
Ve Series 2
What I have done is, I removed the remote part from the damaged flip key and installed it into the new one. So, in other words I have swapped everything around.
I have done my research, (extensively) and cannot find anything otherwise I wouldn't be posting this.
krusing
Melbourne, Bayside
I think lmoengnr was trying to explain to you, there is more in a VE Key Head change-over than just the circuit board,
Thats great you have done your research extensively, but you don't need to be rude about it.
As lmoengnr mentioned, there is also a Chip that needs to be removed from the old Flip Key Head,
and removed carefully if its a non flip key,
Where in the Flip Key, it is located adjacent the hinge of the key blade.
Vs-AclaimII
Ve Series 2
Hey guys, I wasn't trying to be rude and if I was, I apologise.
I found the issues it was missing the transponder from the flip key so, I ended up just ordering a transponder which I had installed and sort out. Thanks guys.
