stubec16
- Aug 19, 2012
- 68
- 2
- 8
- Location
- Victoria
- VE Equipe Sportswagon LPG
Yesterday afternoon was pretty warm, over 30 degrees. Drove about 50 k's with air con on, no problems. Parked the car for 3 hours and the weather got a little cooler into the evening. When we started, the air con wouldn't start. It was NOT a sticky 'minus' switch because the fan continued to work normally. When I changed to defrost I got a message "air con cannot be turned OFF while in defrost mode' - even though air con was showing as OFF. Turned car off and let it sit a couple of times, but it would not reset.
This morning it is fine and working again and as cold as usual.
Once before, it was about 42 degrees and the air con just went off while I was driving. After about 5 minutes it just came back on again.
I have seen a few threads which say there is internal protections, and it will turn off when the gas gets low. The car is only 6 months old and like I say, it normally works fine.
I suppose I'm asking if it could be a software issue that I can live with for a month until the 15,000k service or if I have to take it in straight away and get the gas checked or this problem sorted. We are 50k's from our dealer so little warranty issues like this are painful.
Thanks.
Thanks.
