VE Series II Commodore (OMEGA)
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Shen Long, Oct 9, 2011.
  1. Shen Long
    Shen Long New Member
    Roxby Downs
    WH Caprice 5.7L
    I have a Commy with a 6 Speed auto.
    i would like to know where the speedometer sender cable is located so i can disconnect it for a while.
    Preferably from the Automatic.
    thx
    SL
  2. Calaber
    Lower Hunter Region NSW
    CG Captiva 5 Series 2
    Question: why?
    Are you racking up the k's too quickly so your trying to dud the company for a bit of extra warranty period?
  3. gossie
    gossie Well-Known Member
    Gold Coast.
    VE International 3.6L
    I think we need name, address, cell phone number plus vehicle VIN and registration number for this one.
  4. dmacey
    dmacey Somebody, make me upset
    SSV Series II Sedan Manual & a VK in the build
    Honesty is key, If you want to do something like this, i would suggest taking this question somewhere else. I think yo will find that the majority of people of this forum are honest hard working individuals with a passion for their cars.
    Its clear from your question that this may not be high up on your list.
    As always, good luck with it, but i would be very surprised if the info came from here.
  5. pjdm1980
    pjdm1980 Shut up Jr I'm thinkin!
    Geelong, Victoria
    E1 GTS BUILD NO# 007, GQ Patrol.
    It's the big red one that comes off your battery!
  6. MikeCuzzy
    MikeCuzzy Jumping puddles
    Australia
    2007 VE Omega 3.6L
    I recommend you visit your local Holden dealer, I'm sure they can help you!
  7. Zerone_V
    Zerone_V New Member
    Lexus IS350 (SL)
    You will find Commodores have not used a speedo cable for a while.
    You can try and unplug your instrument cluster....
    But you will find that the speedo and odo arent the only things that will stop working if you do this.
  8. BlueSteele
    BlueSteele Member
    09 VE SSV Sportswagon
    this one can be shelved with the "removal of seat belt warning tone" & "permanent removal of traction control" threads
  9. Jarp
    Jarp Surely You Jest
    VFII SSV A6 W375
    ROFL....Hi I'd like to flog my car around for 12mths without the speedo hooked up then re-hook it back up and sell it to some poor unsuspecting person where is the :banstick:
  10. IS250FSSV
    IS250FSSV Banned
    Brisibane
    2011 Lexus GS 300,Holden Commodore SSV 2009,LX-R
    sent to the local station......
  11. LittleMissVE
    LittleMissVE New Member
    Middle of Nowhere - WA
    VE Clubsport
    What the.....?
  12. IS250FSSV
    IS250FSSV Banned
    Brisibane
    ^^^joke^^^^
  13. itsArthurKomar
    itsArthurKomar sexy beast
    ya asss
    super awesome time machine
    Hey i can help you :). whhat you need is lube and your car...
    go to your car, get the lube, squirt it on the gearstick, take ur pants off and sit on it:)
  14. The Dark Knight
    The Dark Knight The Dark Knight
    VF SS Storm MY14
    I'd recommend you listen to Arthur
    And as said further up in the post as honesty is not your number one priority at least doing as Arthur said should be your second
  15. Shen Long
    Roxby Downs
    WH Caprice 5.7L
    WTF guys...
    It was a general question...
    Why do all of you think that i am rorting something or other???
    People have no faith in other people any more...
    Surely i am not the first person to do this nor the last?
    The question was legit as i wanted to try out a few things without the speedo connected.
  16. Zerone_V
    Zerone_V New Member
    Lexus IS350 (SL)
    Technically, you cant....
    There s no speedo sender cable.
    The speedo signal is be virtually generated by the ABS wheel speed sensors.
    Disabling all these would disable ABS, Traction Control, Stability Management, as well as log many many error codes, and make the car un-drivable....
    Maybe if you explain WHAT it is you are trying to do people may be a little it more sympathetic.
    You should be able to understand, with the limited amount of information you have provided, people are very dubious about the reason why you would want to do this...
    I cannot see a single legitimate reason, so maybe you can enlighten us as to WHY you would want to do this ????
  17. Boonz
    Boonz Donating Member
    berri, south australia
    green 355 VG ute
    This would have to be of of the dumbest things I've heard.... no you can't disconnect it, your car car wouldn't go anywhere without a speed signal cos the trans wouldn't know what to do with itself!
    Sent from my MB860 using Tapatalk
  18. captaincupcake
    captaincupcake New Member
    VE Omega - SS Mock Up
  19. MikeCuzzy
    Australia
    2007 VE Omega 3.6L
    Please explain to us what these very specific, yet unmentionable things you are attempting to do that require you to remove the speedo from your effectively brand new car? I can say I have never thought that any situation required me to drive around in my VT with no functioning instrumentation.
    Please enlighten us.
    And remember, the reason we have no faith in you, is because what you're doing is violating the warranty of your car, the law and putting yourself in danger should you be able to actually start your car after "tinkering".
  20. SirYesSir
    SirYesSir Banned
    Brisibane
    2010 S2 Calais/2008 SR5 Turbo
    I like Arthurs idea of the lube....send us a pic will you?
