boneart
- Sep 30, 2009
- 73
- 17
- 8
- Location
- Auckland
- Website
- www.boneart.co.nz
- VFII SS-V Redline
Just in the middle of doing the speakers in my SSV but I did not want to play around adding amps and rewiring the whole thing at this stage so I am just replacing the stocks with something a bit better.
Its not particularly hard going that way as the doors have plenty of space and 6 1/2s pretty much just drop in.
The stocks are 30 watt 2 ohm splits in the front (6 1/2 in the front door plus dash mounted tweeters) and 2 ways in the back doors. As I am staying with the stock wiring and head unit I am putting in Infinity Kappa 2 ohm units (2 way in the back and splits in the front).
Only little trap is the minor wiring tweak for the splits. I was told "just replace the existing tweeters with the ones that come with the new splits but thats not strictly correct, you MUST use the crossover that comes with your new splits or you risk damaging the tweeters.
Proper splits take the full range line from the head unit into a crossover box which then splits out to the cables for the mid and tweeter. In the Holden they have gone cheep so the feed from the head unit simply divides under the dash with a full range feed to the door and also to the tweeters. Each tweeter then has a filter/capacitor soldered to it to cut out the lower frequencies.
In order to put in after market splits you need to connect the feed going to the door to the crossover and either find the tweeter wire under the dash and take that to the crossover or just drop a new wire from the tweeters down to the crossover instead.
Its not a hard job, just a bit time consuming but the results are certainly worth it.
I will do a full write up on it with pics when I get some time
At this stage I have just disconnected the centre speaker and one day I will look at replacing the subs with something a bit better. The stocks are 8inch 50 watt 2 ohm units.
