Thanks heaps guys. I've checked the fuse and relay for the rear demist/defog. It all appears ok. I can push the button and hear the relay click under the bonnet now. Might have been an issue with the contacts as I can now do the re-set and hear the flaps move etc.
I don't think the re learn has helped though. I am getting the same results. The A/C works fine. It blows hot air when i select hot and cold when i select cold. As mentioned above by Skylarking the only issue I have is that the air does not come out of the front center vent sometimes. Usually the first time I start the car. Nearly 90% of the time I start the car it doesn't work. I then have to turn off ignition and restart just to get the center vent to work. Pretty frustrating.
I might have to get under the dash and see if I can actually see the actuators move. Are all the actuators the same part number? Could I swap a couple around and reset them. Hoping this would move the problem so I knew one of them was faulty.
cheers
cheers
