VrWagz1
The Wagon on Wheels..
- May 5, 2008
- 2,438
- 29
- 48
- Location
- wollongong
- VE SSV MY09 Auto Wagon
Ive been reading threads here that were quite old as far as the earlier VE's Auto transmission issues with 2nd-3rd flaring/slip/flatspot issues.
I have a VE SSV MY09 L98 wagon that is flaring between 2nd and 3rd, has been for 12 months or so now and is exactly to spec on the said "known issue" by Holden back in the day as per this thread
http://forums.justcommodores.com.au...k-when-engaging-d-r-other-owners-comment.html
However now its nearly 2017 and i doubt Holden is going to warrant the transmission on my 2nd hand 2008 VE Wagon. My question is what are people doing/options out there to get this fixed at a reasonable $$price now.
-Replace Trans, but with what? Do VF trans fit up, wiring harness ect.... try and find a cheap 2nd hand working one, tips?
-Rebuild current trans? Too pricey$$ for me though
-Is there a way to "Repair/Fix" the Transmission. That said, does anyone have a clear concise understanding on what the actual problem is? Im not real flash with Auto's but I read in the other link that there was a "Seal issue", but then also read its a "Bleed Valve Issue"; which is it and what exactly? Is it a 20cent part that forces rebuilds
-Buy a rebuilt trans, but is there certain "serial numbers" or "models" i need to stick to for the ecu? However likely too $$expensive option.
If there are other options im keen to hear about them. If it was my old VR or Jeep id just throw in a cheap <$600 2nd hand Transmission, not much effort at all(Well......Jeep was a pain).
I want to ideally fix this for under $1K.
Cheers:Thumbsup:
EDIT
Bulletin No.: 09-07-30-004C prety much covers this issue. Click link below to go to Post #14 with the details on this.
https://forums.justcommodores.com.a...ng-issue-whats-best-fix-2.257487/post-2857023
Another TSB, not directly related to this issue but interesting none the less
http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM505581/SB-10043845-3346.pdf
Cheers:Thumbsup:
EDIT
