VE SS Oil temp after cam install
Discussion in 'V8 Development and Modification' started by Tuff.SSVoodoo, Dec 22, 2013.
  1. 07GTS
    07GTS Well-Known Member
    Australia
    VEGTS BLOWN E85
    yep there is a spot for an oil temp sensor on the LS series engines, can also be in with the oil pressure sensor if it has 3 wires going to it could be a twin sensor or depending on model engine could be on either side of the sump...
  2. PIR4TE
    PIR4TE Banned
    AWOL with Ari
    Black Pearl
    Yes Ls1 & LS6 definitely, no sensor on our Gen IV.
  3. Tuff.SSVoodoo
    Tuff.SSVoodoo New Member
    Burnie
    VE SSV Ute
    Just asked my friend who has 2 cammed L98s and she says hers run around 105-115° so mustn't have anything to worry about :)
    Sent from my GT-I9505 using Tapatalk
  4. PIR4TE
    PIR4TE Banned
    AWOL with Ari
    Black Pearl
    Nah, I agree mate.
  5. Vs hsv manta
    Vs hsv manta Member
    Mackay
    Vs hsv manta
    My mate has just had a 427 stroker put in his ls3 with cam and head work,
    oil temp is going to 120 degrees after a quick squirt and has him concerned
  6. Tuff.SSVoodoo
    Burnie
    VE SSV Ute
    Whild I was getting my ute tuned and had the 5w30 in it after 5 or 6 power runs it got up 122° then out the 10w60 in amd hasnt gone above 116
  7. immortality
    Sth Auck, NZ
    I was told one that you need to get the oil hot enough to burn of any moisture that may build up in the crank case. Based on that presumption you'd want to get it over 100° C. How much hotter is the question. I guess it also depends on the oil you are using, a full synthetic can handle more heat than a semi-synthetic or full mineral oil.
  8. Tuff.SSVoodoo
    Burnie
    VE SSV Ute
    Ive been told they can run up to 150°C but that just seems way to high. Id be worring if it got up to 130°
  9. WogBoyz
    WogBoyz 435rkw/590rwhp
    Cairns, Qld
    08 VE SSV M6 Ute
    mine runs at 90 - 95 sometimes dips down to 85 but ive got cooler thermostat and oil cooler ect
    my mates maloo runs between 110 - 125 max also supercharged, cam ect ect and that's up in the hot tropics too
    if it started going over 130 or so id be checking it out just encase
    both running Castrol 10w60 too
  10. Tuff.SSVoodoo
    Burnie
    VE SSV Ute
    What kind or blower is he running? Top or side mount
  11. WogBoyz
    Cairns, Qld
    08 VE SSV M6 Ute
    He's running new harrop fidi 2300 blower on 10 - 11psi
  12. Tuff.SSVoodoo
    Burnie
    VE SSV Ute
    Ah yeah. I may see some boost into my ute. Will probably go with a side mount though
  13. WogBoyz
    Cairns, Qld
    08 VE SSV M6 Ute
    Oh yeah cool cool you will love it mate, I was going to go side but after going for a drive In both top mount was my choice
  14. Tuff.SSVoodoo
    Burnie
    VE SSV Ute
    Yeah ive been in both. Top mounts are a lot more fun but for price and engine wear you cant beat a side mount
  15. WogBoyz
    Cairns, Qld
    08 VE SSV M6 Ute
    keep an eye out for some good second hand kits man as top or sidemount easily can kit the 10k + new with all the good gear, I got mine off a lad on here, nearly half price and brand new looking, saved me heaps
  16. Tuff.SSVoodoo
    Burnie
    VE SSV Ute
    Second hand forced induction. I think ill pass unless I can actually inspect what im buying. Ive bought a "NEW" blown turbo before and same has happened to a mate
  17. WogBoyz
    Cairns, Qld
    08 VE SSV M6 Ute
    oh yeah I wouldn't buy turbos 2nd hand unless inspecting, for blowers but mine was perfect
  18. Tuff.SSVoodoo
    Burnie
    VE SSV Ute
    Yeah the deal seamed to good to be true. Ah well im done with hair dryers. Belt driven boost is the only way to go
  19. WogBoyz
    Cairns, Qld
    08 VE SSV M6 Ute
    oh tru bit off topic haha what turbo car did ya have man?
  20. Tuff.SSVoodoo
    Burnie
    VE SSV Ute
    Td hilux. I was a bush basher before I found the tarmac lol
