VE SS series 2 clutch safety switch
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Mitch-VE6LTR, Jan 5, 2012.
  1. Mitch-VE6LTR
    Mitch-VE6LTR New Member
    Orange
    VE SS series 2
    Does anyone know how to disable the stupid safety start switch on the clutch? So annoying not being able to start without pushing clutch in...
  2. Voodoo_SV6
    Voodoo_SV6 Active Member
    MY12.5 E3 R8 Manual+MY16 VFII SV6+MY11 VE S2 SV6
    I had that in a Hyundai company car 15 years ago. I just wired the two cables together that fed the switch up in the pedal box. Problem solved, but not sure if it's that simple in a VE.
  3. Mitch-VE6LTR
    Orange
    VE SS series 2
    Ok have to try and climb in there and have a look what the set up is. Thanks
  4. evotime
    evotime Member
    not yet
  5. jamesmp
    jamesmp The Photo Journalist
    Sydney, NSW
    MY12 VE Commodore SS
    Are you sure? I just 'tipped' the clutch pedal and it deactivated cruise.
  6. evotime
    evotime Member
    not yet
  7. ryan101
    ryan101 New Member
    whittlesea
    vx ss
    I have a manual vx ss when I brought the car it wouldn't start unless I disengaged the clutch, but now I can start the car with out using the clutch, I don't know what's happened ever since I changed my cat back exhaust I have been able to start with no clutch in! Why is this?
  8. ryan101
    ryan101 New Member
    whittlesea
    vx ss
    Ohh and my cruise control is fine
  9. evotime
    evotime Member
    not yet
  10. ben315vz
    ben315vz Donating Member
    Tamborine Mountain, QLD
    '05 Holden VZ Calais V8
    With my dads VX SS, you can start it without pressing the clutch, I thought that was normal.
  11. ryan101
    ryan101 New Member
    whittlesea
    vx ss
    Has he done something? Has something been changed?
  12. doubledip
    doubledip Member
    VE SSV, LH Torana / LSA / VE E3 HSV interior
    in the tune it can be turned of for a VE (but shouldnt as is in there for safety)
    can do anything with wires as it is a 3 wire potentiometer in the later VE's (earlier S1 07's had 2 switches)
  13. jamesmp
    Sydney, NSW
    Where would I go to have the safety switch disabled? Local auto electrician?
  14. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 6.0 470rwhp
    Aftermarket tuner.
  15. social
    social Ute Finatic
    South Aus
    MY06 6.0L VZ Thunder(na naa na naa..)
    my vz has it, annoying, but yet never accidentally try n start in gear...
  16. azzss
    azzss New Member
    Bushfield, Vic
    MY 9.5 SSV Sportswagon M6 & 08 prado D4D GXL M6
    I know a bloke that tried this on a 6l vz, got it to start without pressing the clutch, but would sit on the rev limiter if he clutched it with the cruise on. I carn't see the problem with it, i've always had manuals and have always press the clutch in before startup force of habit i suppose.
    Cheers.
  17. jamesmp
    Sydney, NSW
    I always depress the clutch when I'm sitting in the car, but often during Summer in QLD I start the car to let the air-conditioning cool down before setting off. That's why it's helpful here.
  18. MYVESSV8
    MYVESSV8 Well-Known Member
    Brisbane/GoldCoast
    VE 6LT M6
    doubledip, with the two switch's which would cause an intermittent starting issue, go to start car get a click, depress release depress clutch generally starts, no weak cranking or anything, just sometimes not starting, could it be starter solenoid
  19. Mbjoz
    Mbjoz New Member
    Darwin
    VE SSV Z
    Just had a read of this thread and no real answer, so i thought i would bump it as I would like to know how to start my commodore with out getting in it. Cheers guys
  20. Rajesh Koothrappali
    Rajesh Koothrappali Banned
    ya mum!
    Tasmaniak can do it. He installs alarms and remote start systems. I've asked him about one for my manual VEIIS SV and as part of the remote start, he disables the clutch safety "feature".
