Hi guys, new to Just Commodores, coming from an AU XR8 as per my sig.
Hope no-one minds me referencing an old thread, I'm hoping it can be developed a little further.
In short I've just bought myself a grandpa VE SS in Ignition with 40 kkms and have a bit of a vision for a cut price (almost) Clubsport project.
Car already has:
- MACE pod filter intake which I'm going to heat shield/wrap, including boxing in the left front corner above and below the rail with plastic sheet (recycling crate)
- 2.5 inch stainless straight through cat-back with x-pipe in midsection (where I'm planning to return the rear mufflers to standard as too loud)
Car will probably also end up with:
- A tune, assuming the tuner thinks there is something he can improve, hopefully bringing the engine up to around 290 honest KWs, so about 230 to 235 at the rears
- HSV or Redline wheels
- Brembo front brakes
- A mild suspension upgrade, which is the point of this thread
What I really want to do is get the car handling a fair bit better than standard without spending a lot of money, therefore:
- Coilovers not an option as dearer than Bilsteins and springs
- Doesn’t really need to be adjustable, just well set up in the first place
- Not interested in lowering if it means I need camber kids etc.., unless a small drop, eg. 1 to 2 cm could make it handle HEAPS better…
- Shock upgrade where I’m probably leaning toward Koni Yellow which won’t raise it either, as opposed to Bilsteins which would probably mean I need new springs or to trim them back a bit with the grinder
- Wondering if I can get away with Koni front and KYB rear as per PIR4TE who used to post on here, if fronts make more difference than rears
- Something to dial out a bit of understeer, either a slightly thicker rear sway bar, eg. 20 mm, or slightly stiffer rear springs with same height as previous, springs obviously being cheaper…
- Probably also change all 4 sway bar bushes to Nolathane for a little more roll stiffness since hopefully bars can’t move about as much
Would be interested if anyone has done something similar, or has any thoughts on the above.
Thanks,
Matt
