VE SS Thunder Ute - Sub install rear, left and right side
mkeman2009
Holden VE SS Thunder Ute
Hi guys,
I know there are a few threads going on about subs for the VE series 2, but i just have one simple question in regards to install.
On the SSV there are 2 factory 8" subs behind the seats on the left and right sides, on the SS Thunder they are blanked off. Would the hole to install them still be there or do I have to cut new holes in the SS? My car is currently being made so i'm just trying to gather some info for my audio install.
Cheers guys.
Fun_Bucket
Cairns White Rock
Cruze II sri
Surely someone from Holden would be able to tell you?
Otherwise assuming they all use the same shell / body, then you'd think that the holes would still be there, possibly with a spot welded cover like previous Holden models.
I'd still give Holden a ring though.
sweefu
VY Berlina V6 / R31 Skyline
I agree with HCVP .. I'd imagine it would be like the 6x9" holes in the parcel shelf of VT-VZ Commodores, just tack welded covers in place.
mkeman2009
thanks guys,
got in touch with my dealer, he has emailed holden to find out.
cheers
VEO55
Brisbane QLD
VE SSV UTE
In a standard ute you will find a plastic blanking panel in the rear quarter. This panel is exactly the same as the 8" woofer panel... Without the hole. They are both thin plastic so reinforcing them with an mdf board will strengthen them a lot, or alternatively build a fiberglass enclosure, you can get about 125mm depth into the rear location.
If you want the genuine part it is sold complete with the factory woofer, I think when I bought a pair they were ~$80 each.
191kieran191
Collinsville
VE Series 2 Thunder Ute
I have a series 2 sv6 thunder ute and your saying that the left and right rear panel can fit 2 8inch subs.
VEO55
Brisbane QLD
VE SSV UTE
Yes, 8" subwoofer will fit.
This picture is of the opening, there is a plastic panel that sits in there. Sorry for bad quality but better than nothing.
And this is with factory trim reinstalled.
Bass man
Karratha
2012 VE SS Thunder
Thanks heaps! Everything I needed to know! Have picked up mine now and just need to find some time off work to get started. :beer chug:
