This site has a talk about propane and the octane rating of 101 lsa.colorado.edu/summarystreet/texts/propane.htm
This site has the octane rating of butane 91en.wikipedia.org/wiki/Octane_rating
as far as auto mix with butane being good stuff it is ok as long was it is mixed in correct amounts but the octane rating of propane is deminished when mixed with butane,
Yes, that is correct......but as I said, unless you are running a highly modded motor, ie compression ratio > 11:1, then the extra RON of straight propane isnt really a consideration. Regular mix of lpg still has a RON better than 98 premium unleaded. Given that the RON of even straight butane(which cant work without a fuel pump) is as good as regular unleaded.....what is the problem?
why dont they use mixed gas in household bottles answer it burns crappy and it tends to block jets quicker so when theres larger than normal amounts of butane in the automix guess what it can make your car run bad and block your gas system
You are confusing the poor burning of a butane/propane mix in systems that are designed for propane only, with how it is burnt in a car engine. The jetting of the burners in domestic systems are designed for straight propane, not a mix including butane. Butane will not burn as well at low temps, producing more CO, which is possibly one of several reasons as to why domestic systems run propane only.......
and as for emmisions if you get a more efficent burn the by products deminish as the same way that 98 octane fuels burn cleaner in your car and produce more power.
Some fuel companies produce a fuel that produces less toxic emissions as a 98 Octane fuel than their 92 rated fuel, however, it is not a given that higher octane fuel burns cleaner, certainly it will not have any real effect on the CO2 output. It is not a given that the car produces more power either.
also could you show me where you got your info and butane haveing more power per litre
Where, I dont know, something I took in somewhere some time........Why not just go to wikepedia and look up butane and propane and look at the heat of combustion if you are in doubt,?
PS: your posts would be easy to read if you used paragraphs and more than one sentence.
