Ve2011ssv
- Oct 27, 2019
- 4
- 0
- 1
- Age
- 45
- Location
- Sydney
- VE Commodore ssv
Hi i am having an issue with ABS faults. 2011 VE COMMODORE SSV AUTO.
1. abs Fault CO131 - Brake switch circuit.
2. abs/tcs Fault CO161 - System pressure circuit.
The brake switch circuit was replaced and it is still throwing the same faults.
It's happening Intermediately. I left the auto electrician yesterday and half hour into the drive it threw the faults. Went back to him and he cleared the faults.
I then drove 1 hour after the faults were cleared and it didn't throw a fault. I then drove for 10 minutes stopping and switching off in between and it did not throw the fault. Then this morning that same faults came up again after 10 minutes.
All brake lights are working. Drive the car with the scan tool plugged in and slammed the brakes on. Abs worked. It said the Pressure was normal.
I am desperate for help. I have a tumour on my pancreas and have to travel for treatment. The mechanic said it will fail a pink slip because of it. I am only on a pension and i cant afford to keep replacing things until i find the issue. I have already paid 5 hours and the brake switch. Which is the switch on the brake peddle.
