Ve ssv high idle after MAF/TB clean
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Seanssv08, Mar 7, 2018.
  1. Seanssv08
    Seanssv08 Member
    Ve ssv
    Pic is without the cover on obviously its an orrsum otr. Ive had it for 5 years never had an issue till now. This is first ive cleaned the MAF and throttle body
  2. Seanssv08
    Seanssv08 Member
    Ve ssv
  3. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
    If it's a coolant temp sensor error, have you checked the coolant temp sensor connector to make sure you haven't knocked it or pulled the loom at some point?
    monstar likes this.
  4. Seanssv08
    Seanssv08 Member
    Ve ssv
    Yeah ive checked that..
  5. monstar
    monstar Naturally as-pirated
    depths of Hays Inlet
    Peugeot 207 GTi
    Mate it might be the photo but the MAF is not connected?
  6. alba81
    alba81 New Member
    Wollongong
    Holden Calais ve v
    I'm not a mechanic but if you forced open the tb with ur hands I'm pretty sure U wrecked it
  7. Seanssv08
    Seanssv08 Member
    Ve ssv
    Yeah this is when i was putting it back together. I took a photo to send to a mate..Its definitely connected thou. I was at work when i posted this
  8. Seanssv08
    Seanssv08 Member
    Ve ssv
    Yeah ive read mixed responses..ive spoken to my mechanic which will have a look tomorrow if he has time when i finish work but he said theres a couple relearns to perform or it could be a totally different issue. I told him i did it by hand and he wasnt to convinced that would be the a problem..
  9. 07GTS
    07GTS Well-Known Member
    Australia
    VEGTS BLOWN E85
    the throttle blade is fine to move as long as its not powered up, if key is off it should move easily and its fine to do but if u notice any resistance then i wouldnt push it, the temp sensor could be faulty if its showing a code and also changes the idle id look into that, if the temp reading changes it will change the fueling also when they fail they usually show -40 deg which will add alot of fuel and go OL
    monstar likes this.
  10. Seanssv08
    Seanssv08 Member
    Ve ssv
    I replaced both thermostat and coolant temp about 4months ago both brand new. The temp is going from mid 80s down to like 50 then back up...im engeering.mode the only thing showing -40 is the trans sump
  11. 07GTS
    Australia
    VEGTS BLOWN E85
    if its going down to like 50 then its cool enough to bring it out of CL (some bout 55c is the OL limit) and it shouldnt be varying the temp anyway it will always interfere with fueling, id look at this first then u can get some consistency with the sensors then see what the rest is doing
    monstar likes this.
  12. Xplaya
    Xplaya Active Member
    NZ
    HSV
    Off Topic: But what OTR is that? The filter is so easy accessible compared to mine ..
    Edit: Oh wait, this is a photo of it pulled out from the front of the radiator
  13. Seanssv08
    Seanssv08 Member
    Ve ssv
    Its an orrsum otr. Thats where it sits i just has the top cover off
  14. Seanssv08
    Seanssv08 Member
    Ve ssv
    So took it into the mechanic this arvo. Perfomed idle relearn (disconnect battery, then 10min idle) no change..found corroeded coolant sensor plug..so monday will put a new plug on, if that dosent fux the problem, then he has a spare MAF hes gonna to swap over..see how we go..
    monstar likes this.
  15. monstar
    Peugeot 207 GTi
    Wow that’s a beautiful bay!
  16. vr304
    vr304 Well-Known Member
    Auckland, New Zealand
    2007 ssv manual
    Should get some hi temp blue paint and paint the grey bits of ur engine cover blue it will match the car nicely and look so much better than that dull grey
    monstar likes this.
  17. Seanssv08
    Seanssv08 Member
    Ve ssv
    Update:
    So car was with mechanic all day. He said hes tested everything. Pulled of TB inspected it. Checked all readings and apparently its doing everything correct to what the ecu wants it to do...fuel readings correct. MAF is correct.he doesnt know what is wrong...not happy cos it cost me $300 and i still have this problem...
  18. monstar
    Peugeot 207 GTi
    So not fuel or sensors (I presume mech checked O2), and ECU doesn’t report misfire even, try ignition: plugs, leads, coil packs.
  19. Seanssv08
    Seanssv08 Member
    Ve ssv
    Like i dont know..he had it all day and checked everything..if it doesnt sort itself in couple weeks ill look at getting a new ecu maybe..or im just going to trade it in. ive had it for 6 years and the past 12months its been 1 thing after another. ive lost interest in it..
  20. Seanssv08
    Seanssv08 Member
    Ve ssv
    So ive uploaded a a short clip of what my car is doing. The car runs ok and idles fine when statinary but when in neutral and rolling or when you come to a stop itll rev high. Once you stop moving it returns to normal..in the clip im rolling down the road in neutral at 40ks and the revs are up and down. Sometimes it just sits at 2000rpm and other times it does this..itll kepp doing that until you put it in gear or come to a stop
