Hi PNR51, I can tell you that I took it to the local Holden dealership on the 29th, and they had the car overnight so they could hook it up to a scan tool and test it on a cold boot, because I'd showed them all of the stuff that I'd collected, like how I'd replaced the battery with a much larger battery only a few weeks ago, and how it had only been serviced a week or so after that, and I played them video footage of the car sputtering on in its initial cold start up, as well as photos that I'd taken of what the car is showing me in engineering mode (like how one day it was showing that the battery charge was at 47%, and then without even driving it for a couple of days, I started it again and it was showing me the battery charge was over 96-99%, and the battery voltage was reading fine, and was around 14.1-14.7 volts whilst it was running).
They said that they thought that it might've been the starter motor for some reason (but I've got no idea of why, because if it was the starter motor then you'd expect it to do the same thing each time it started, or at least a lot more than just on the first boot up of the day). Anyways I told them that it'd been scanned when it was serviced, and there were no tripped error codes, and gave them a copy of the diagnostic report, as well as all of the stuff that my mechanic has done to try and find the cause of the problem, like 2 bottles of injector cleaner, cleaning both the throttle body and MAF sensor, ad well as checking for anything visibly not right, and they know my mechanic very well and said that they're an excellent mechanic.
All in all it seems like it was a mystery to them as well, and they were just taking stabs in the dark on what might be causing it, and I told them to call me if they found the issue, so I could work out what to do. They did a cold boot with a scan tool hooked up, and it didn't detect any tripped error codes, or any misfire, or anything like that, so they were really at a loss as to what was causing it also, so they thought that it might've been a possible carbon build up around the valves and in the combustion chamber, so they soaked it in some sort of carbon removing product for 3 hours, and then gave it back to me after they tested it (but because they weren't going to have it for another night they couldn't do another cold boot test), but they basically just charged me for an hour of shop labour, and must be whatever the cleaner cost, but couldn't tell me if it had fixed it or not, and that I'd just have to see how it went
I started it this morning, and it wasn't as bad, but still there, but I'll post an update in a couple of days time and let you know how it's all gone, because it seems to have everyone completely stumped
